honda vfr750 1996 leaking gasoline
Discussion in '3rd & 4th Generation 1990-1997' started by sadykolo, Nov 7, 2024.
  1. sadykolo
    sadykolo New Member
    I bought this motorcycle and it wasn’t running, now i fixed it and it starts but it doesn't work at idle speed without pressing the accelerator, and the engine stalls right after i release jt. And this hose leaks gasoline every time I accelerate
  2. sadykolo
    sadykolo New Member
    The motorcycle hasn't been started for over a year and it's been standing all that time. It's had gas since that time too.
  3. steveindar
    steveindar New Member
    Tanzania, United Republic of
    I would suggest pulling the carbs and giving them a good clean first. Keep it simple and small steps. Flooding also causes all sorts of problems. And get new fuel. Check the tank inside for rust.
    Sent from my TECNO KG5j using Tapatalk
    sadykolo likes this.
  4. squirrelman
    fuel is leaking past one or more float needles
    Agree with all of the above. The tube you are holding is the carb bowls vent. Your carbs are dirty/clogged from sitting with fuel and need servicing. REAL servicing, not fuel system cleaner added to fresh gas.
    You need to check your oil for gas as well.
  6. sadykolo
    sadykolo New Member
    will try, thank you !
  7. sadykolo
    sadykolo New Member
    i’m sorry but what do you mean by checking my oil for gas ? if there’s any gasoline in it ?
    Exactly. Carbs that overflow as you describe will often pour it down the intake tract, into the cylinders and into the oil.
  9. sadykolo
    sadykolo New Member
    oh, i see, thank you !
  10. squirrelman
    as capt 80s said, oil dilution with gas can kill an engine, so check dipstick or oil window, and change oil if theres any doubt.
