How do I know if the carbs need synching?
Discussion in 'Mechanics Garage' started by daveyto, Mar 12, 2010.
  1. daveyto
    daveyto New Member
    Scarborough, Canada
    How do I know if the carbs need to be synched?
    Will the bike run poorly?
    Stupid question but I thought I would ask anyhow :-0
  2. TOE CUTTER
    When you get done synching them you will know that you do not.
  3. squirrelman
    Inability to run smoothly at a steady speed or at idle and surging at low speeds are 2 common symptoms.
  4. KC-10 FE
    KC-10 FE New Member
    The most likely symptom of un-synced carbs will be abnormal throttle response & possibly a minor vibration. If you have access to a guage set, it's not hard & cheap to do. Try it just for the learning experience. It was spelled out completely in my Hawk GT maintenance manual.
    KC-10 FE out...
    :plane: :usa2:
  5. daveyto
    daveyto New Member
    Scarborough, Canada
    the bike once started runs super sweet at 60km /h ( 45mph?) above that it seems to struggle..
    Thats probably the issue..
    thank you squirrel!!!
  6. daveyto
    daveyto New Member
    Scarborough, Canada
    i used to have a nice set of gauges but i gave them away when i sold my kawi...i had no intention of riding again until they passed a law in toronto that stated that motorcycles could park for free in downtown toronto.
    I saw what looks like a good set on ebay for $100.oo plus shipping and think I might go with them...
    thanks for the advice
  7. TOE CUTTER
    From your other post you stated it has a jet kit, did you install it ? If you did or did not, what did you run the needles at and what did you install for jets? On a stock bike a tiny bit of jetting goes a long way. Dynojet needles are way to aggresive for any street use and the jets are about the same and the numbering on Dynojet jets does not match OEM sizes. If your anything like me I would prefer my bike run perfect than stumble through the throttle for a possible gain that is not there.
  8. zielarz
    zielarz New Member
    detroit
    Its got to be carborator-p
  9. squirrelman
    Wait a second there Davey, i don't think the synch has anything to do with your problem. Synch problems are most apparent at low and moderate speeds with small throttle openings.
    Instead, the needle setting or wrong main jet are the most likely issues. Replace the plugs if they appear fouled.
  10. TOE CUTTER
    +1 with Squirrel. Keg of beer say's it way to fat on the main or needles are too high....Two kegs say's both. Jet kits are evil.
  11. daveyto
    daveyto New Member
    Scarborough, Canada
    no...I did not install the kit...I will gladly remove it. its some kit that came from some canadian co. in montreal. i definitely prefer a perfect running bike...oem all the way
  12. REEK
    REEK New Member
    Sacramento CA
    My understanding from way back when I used to sync my own carbs (FI on all but 1 of my bikes now) is that an early sign of needing a sync is an unsteady idle.
    One thing to look at, if the carbs or bike has been apart is the drain hose from the carb ( some older bikes - like my old EX500 had em) can be routed incorrectly. And by 'Bernoulli' effect cause higher speed stumble and missing symptoms. I did that by accident - re-routed the hose. Sucked bad until I put the hose back to the original location (for the old EX it was right behind the swing arm pivot), then all was fine.
    I've long since dumped alot of my tuning skills due to FI bikes but carbs are pretty fun to work on and adjust. You listen to the exhaust on/off throttle, check the plugs, etc... Of course, if you aren't into it, it can just be a big pain in the arse!
    good luck!
