How do you turn the rpm's? Bike running at bit too slow!
Discussion in 'Mechanics Garage' started by sunofwolf, Jun 30, 2015.
  1. sunofwolf
    sunofwolf New Member
    I think there is a little knob that turn up the rpm, its running too slow and stalls.:mechanic:
  2. BWeiss
    BWeiss Johnny Partseed
    Rancho Cordova, Ca
  3. sunofwolf
    ok. thanks -I think some how it got push inside a little
  4. Gator
    Gator Member
    Better find out why the idle changed.
  5. sunofwolf
    Don't know, maybe the vfr is now getting used-I adj some. I will try and set at 1200 when really warmed up well and see if that works. perhaps the cable just needed to be tighten up a little. check out the brake pad deal I got-those pads go for $150-i paid $62 shipped-JC whittney -one screwed up company-they don't know what they are doing. The order has shipped. I used some pj1 cable lube maybe it was sticking-adj the screw and the pj1 lube should fix it.
  6. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    Try setting it a little higher SOW, say 1300-1400.
  7. sunofwolf
    what does the manual say id speed is? Isn't 1200? It was at 500 way too low and stalled a few times, I didn't notice this till today, but yesterday it was slow too' , I would think 1200 would work. I used some pj1 cable lube.
  8. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    your cable has nothing to do with your low idle problem.
  9. NorcalBoy
    1200 rpm (+/- 100 rpm)
  10. rjgti
    rjgti New Member
    regina sk
    set it to 10,000 rpm, will launch hard then
  11. sunofwolf
    I was able to get the rpms up to 1000, I am sure a bit more turning on that knob-I can get it up to 1200, it just seems hard to turn. Oh I wonder if I hold the throttle open would it be easy to turn? Maybe closed makes it hard to turn.:bowl:
  12. Gator
    Gator Member
    500....... something is not right.
  13. Aimbot9000
    Aimbot9000 New Member
    Mount Holly,nc
    well there is an understatement. And it has everything to do with the knob on the bike
  14. OOTV
    OOTV Member
    I see what you did there, clever! :wink:
  15. Gator
    Gator Member
    Don't insult knobs. lol
  16. sunofwolf
    well next time ,I see if I can get 1200 that knob is very like dealing with BB at a troll bridge. If the rpms go too low it takes too long to get the rpm's back up fast.
  17. Badbilly
    SOW may be pulling his knob rather than turning it. s/min rather than r/min.
  18. sunofwolf
    he's back , I wonder how many old ladies had to pay his toll today. He's not George Patton, nobody looks forward !:bump2:
  19. Gator
    Gator Member
    So SOW, did the bike run at normal rpm's then out of the blue drop to 500 rpms?
  20. sunofwolf
    some how it just dropped to 500, I don't see how I wouldn't notice. it barely runs at 500.
