how much do you think $800 will get me?
Discussion in '1st & 2nd Generation 1983-1989' started by thermostate, Jul 12, 2009.
  1. thermostate
    thermostate New Member
    jacksonville,fl
    I have a 86 Honda vf500 and its going to the shop tomorrow and I only have 800 to put into for a clutch problem!
  2. reg71
    Sikeston, MO
    you can rebuild both the master and slave and change the clutch plates and springs for way way less than that... I'm gonna say like 200 or maybe a little more....
  3. crustyrider
    crustyrider New Member
    North Country, New York
    it could get you a hand job at the mustang ranch........
    buy a manual and do the work yourself....you'll save a bundle
  4. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    doing it manually saves in many situations... lol
  5. calculator
    calculator New Member
    Red Deer, AB
    Address please?
  6. Pcohen
    Pcohen New Member
    jonesboro, arkansas
    changing the clutch is super easy! 4 bolts and just pull it off, replace the discs and put that bad boy back on!! 1 hour tops and you will probably need the seal for the right side cover.
    hey take that $800 and buy another 500. I bought a parts bike for $200 and it has saved my bike and my pocketbook many times
  7. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    thermo man its super easy you can rebuild the mast cylinder and slave and new clutch and gasket for under 200.. man i would just do that save that cash while you can
  8. Mark Somerville
    Mark Somerville New Member
    Napa, Ca
    Just to confirm/echo what everyone is saying: it's true.
    If you do your own brakes the simplicity of the clutch work will surprise you. Most bikes are so much more well designed than cars. If it were a BMW you'd still have to break it in half to get to the clutch, not Hondas though.
    BTW anyone want to buy a BMW? The clutch is fine at the moment...
  9. midias
    midias New Member
    Rochester NY
    I can do a V45 magna clutch in less than a hour and it only took me an hour and a half my first time. download the manual and for about 200 in parts you can replace the clutch and gasket rebuild the master and slave and save your self an assload of money.
