How often do you change your clutch fluid and what grade do you use.
Discussion in '6th Generation 2002-2013' started by 25thVFR800, May 30, 2017.
  1. 25thVFR800
    25thVFR800 New Member
    Toronto, Canada
    I've had my VFR for only a week so I'm getting up to speed.
    Clutch works great but is at lower limit line roughly
    Previous owner said he replaced it 3 years ago.
    It is clear and clean
    Am I able to just unscrew top of hydraulic clutch fluid reservoir and fill it up a tad or leave as is.
    What grade fluid do you use I do not see it in manual.
  2. bitterpil
    bitterpil New Member
    Northern Virginia
    You use Dot 4 brake fluid should be on the reservoir cap. I change mine every time I change my brake fluid. Leave it alone and or bleed it out an swap fluid. Cover your bike and all exposed painted parts around the reservoir when dealing with this stuff. The brake fluid makes a good paint remover. Towels, plastic wrap or both make a good barrier.
  3. carlgustav
    carlgustav New Member
    Heart of Dixie
    I use Dot 5 silicone fluid (only for the clutch), changed fluid immediately after I purchased my bike (new). Have had it in for 9 years, no issues. Use same for my track bikes. And did the same a long time ago for my '84 VF700, fluid has been in there for over 15 yrs. That said, I don't mind experimenting. Going with the manufacturers recommendation is generally best :biggrin: ...
    ACE
  4. NorcalBoy
    Pil is correct. DOT4 is the factory recommended fluid for the clutch. If it has been three years, I would completely drain the entire system, clean out the res, flush with new fluid, and do a final bleed.
  5. Aimbot9000
    Aimbot9000 New Member
    Mount Holly,nc
    I flush my clutch and brake yearly but that's probably overkill
  6. ridervfr
    Belgium
    Have a spray bottle with some H20 close by in case your less than perfect handling that stuff as it eats paint plastic parts. Not bad to mist the bike either, top secret stuff I dont mind sharing with other viffer riders :peace:
  7. NorcalBoy
    Not really, I think that is a smart interval.
  8. clarkm8
    clarkm8 New Member
    Another DOT4 user here. I do it every year as well. Besides, it is not too expensive.
  9. rckrzy1
    rckrzy1 New Member
    I have a brake fluid tester, it measures moisture , cost about $10 on ebay, use it on all vehicles. So no doubts, it's what Tech inspectors use as well.
  10. vdrive
    vdrive New Member
    florida
    I replace clutch & brake fluid with dot 4 every few years or when the fluid in the window turns dark.
