How the $%^& do you set the clock?!?!?!?
Discussion in '6th Generation 2002-2013' started by risgett, Nov 26, 2012.
  1. risgett
    risgett New Member
    Florence, SC
    I'm an IT professional and damn if I can figure out how to set the clock. I found an old thread here, but the link no longer works. Can someone please enlighten me?:crazy:
  2. davjohns
    davjohns New Member
    Huntsville, AL
    I just had to change mine when I got to Belgium. Hold both buttons for a few seconds. That'll put you in the clock mode. Can't recall which button goes up/down or such, but once you are in clock mode, you should figure it out pretty quick.
  3. CharlesW
    CharlesW New Member
    Ankeny, Iowa
    It's pretty well covered in the owner's manual.
    Here's a quick summary.
    Digital Clock
    Turn the ignition switch ON.
    Shows hour and minute. To adjust the time, proceed as follows:
    Push and hold both the SELECT button and RESET button for more than 2 seconds.
    The digital clock will be set in the adjust mode with the display flashing.
    Push the RESET button until the desired time and AM/PM are displayed.
    To end the adjustment, press the RESET button 5 seconds after the last adjustment, or turn the ignition switch OFF.
    Note:
    The time is advanced by one minute, each time the button is pushed.
    The time is advanced by ten minutes, when the button is pushed and held.
    Addendum: If you go past the correct time, you have to cycle all the way around again. Take your time and do it right initially.
  4. Arnzinator
    Arnzinator New Member
    Central Massachusetts
    Easier to tell everyone else to adjust to your schedule ;)
  5. 34468 Randy
    I usually get mine changed about a month before it needs to go back. It is simple but a royal pain in the ass. But ChuckieW has got it nailed.
  6. Bryan88
    South Africa
    Durban, South Africa
    I think the ignition has to be turned on
  7. risgett
    risgett New Member
    Florence, SC
    Thanks guys! I got it set.:cool:
