how to fog 6th gen vfr.
Discussion in 'Mechanics Garage' started by jeange, Nov 12, 2011.
  1. jeange
    jeange New Member
    I was trying to figure out how to fog my 2005 vfr 800. I removed the air filter but there is 4 throttle body holes and I have one spray can. Do I spray in one hole after another until the engine quits or is there another procedure that I should follow?
  2. Davis5g
    Davis5g New Member
    Pittsburgh, PA
    How long are you planning on storing the bike? Fogging might not be necessary.
  3. jeange
    jeange New Member
    6 to 7 months, I would prefer to fog it
  4. Davis5g
    Davis5g New Member
    Pittsburgh, PA
    Ok that is a good long time. You could always kill the fuel and ignition, and crank it over while spraying the fog in each cylinder.
