How to raise the rear end
Discussion in 'Mechanics Garage' started by daveyto, May 29, 2011.
  1. daveyto
    daveyto New Member
    Scarborough, Canada
    I upgraded my 3rd gen front springs to racetech 1.0 and now the bike's front end is a little higher than the rear. Can anyone please advise how to raise the rear end to balance out the ride.
    More rear pre-load will help a bit, but you might also consider raising the forks about 8-10mm in the clamps.
  3. daveyto
    daveyto New Member
    Scarborough, Canada
    I actually like where the front is...i want to get the rear up higher.
    When you say preload do you mean adjusting the shock with the tool?
  4. daveyto
    daveyto New Member
    Scarborough, Canada
    Actually I am looking to shim it up...Any ideas?
  5. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    Thurn Morosports sells a tail riser for your 3rd gen that is the shit. I had the 4th gen one when I Had the th gen.
    BZ
