I found "flaking" or "cracking" inside the crankcase cover
Discussion in 'Mechanics Garage' started by jwf88, May 31, 2013.
  1. jwf88
    jwf88 New Member
    Curious if anyone can tell me what this is? It's sharp to the touch. Looks weird. Should I worry about it?
  2. kennybobby
    kennybobby New Member
    Sand casting of a metal part leaves a rough surface from the mold, with sharp scales and flash on the surface. You can knock it loose or file it off or polish it too, if you have time--just be sure to get all the loose debris cleaned out. It's not pretty, but it doesn't show, and the factory didn't want to spend any time or money on it...
  3. mastergregor
    mastergregor New Member
    Arlington Heights, IL
    Exact and to the point answer! Messing with it might leave residue/dust that might get into the oil. I would just leave it alone.
  4. jwf88
    jwf88 New Member
    Hahahaha! and here I was thinking that something had been rubbing against it causing damage. Thanks for a solid answer!
