i need a bit of info.
Discussion in '1st & 2nd Generation 1983-1989' started by dirtfreak, Oct 19, 2012.
  1. dirtfreak
    dirtfreak New Member
    Hi guys.
    I need a little info. Does anybody know if a 1986 VFR700 fuel tank will fit perfectly on a 1989 vfr750.as I need a tank & I've Got the offer of one.I think it will but I just want to be sure before I buy it grommets thousands of miles away.please help me if you can.
  2. Maggot
    Maggot New Member
    Park Ridge, IL
    Go to someplace like BikeBandit.com and check the part numbers if they go back that far.
  3. squirrelman
    You know that we in the USA never got VFRs in '89, but i believe the 2 tanks are interchangable.
  4. dirtfreak
    Thank mate, that's good feedback.they do look the same.there's a tank in the USA that I wanna buy if the guy gets back to me.
  5. artee
    artee New Member
    Rochdale,
    Hi
    Tank will fit but fuel sensor is different.
    86-87 has a stick sensor wheras the 88-89 uses a float.
    Not sure if the sensors can be swapped over though
    Roger
