Hello, I am new to VFR's and motorcycles as a whole and I picked up a project 1986 RC24 because I though it would be fun (it isn't) and I am having trouble with electrical, it could be that it's having a hard time since it sat for a while but I have replaced the wiring harness, fuse, ignition (actually new), turn signals (only has rear + one front), spark unit ecu thingy, and dash from a f2. When i try to start it, the starter relay clicks/whines, for the most recent attempt the starter finally sounded like it's doing something + the fuel pump "pumped" a pump (now fuel just flows through) + the turn signal no longer flashes (it is on and when i go to indicate, the light goes out) and the brake light no longer lights up (only consistent dim). So, my question to everyone is: ideas on what could be wrong and where can I get actually new electrical + parts? also, should I disconnect the starter from the relay/solenoid and jump it to try to get it started?
