I think something is wrong with my speedometer
Discussion in '5th Generation 1998-2001' started by Matasickle, Jun 22, 2012.
  1. Matasickle
    Matasickle New Member
    CT
    The speedometer has been acting up on my 2000 VFR.
    It started off as just modulating between a 10 mph range.. Exampl:. I'd be going 30mph and the speedo would show the needle jumping from 30mph to 40mph. Now it has progressed to just showing 0 mph or a really high mph if I'm moving along fast.. nothing in between.
    Anyone have any ideas?
    Should I purchase a new one?
    Also, does this effect my tach/tripometer/fuel level reading in any way?
  2. reg71
    Sikeston, MO
    you know that reminds me, mine is all boogered up and it still works. I keep meaning to buy one but I have never even priced it. The end of yours on the left up there where it looks like a bolt head would fit on mine looks like chewed bubblegum. Weird that mine would still work and yours acts up...
  3. TOE CUTTER
    Make sure the coupler has not been pushed back on the shaft too far and is just not being turn by the bolt head, mine has done it a couple of times.
  4. Rangerscott
    Rangerscott New Member
    Texas
    I replaced mine with a low mileage vfr off of ebay. Any year model should work. Two bonuses if you get a low mileage one. 1. It's newer than yours. LOL and 2. The plastic nut will be in better shape.
  5. Scubalong
    [SUB] [/SUB]Just replace the plastic coupling about 20 bucks the problem fix.
