I just picked up a new leftover 2014 today. It seems to be idling high even after fully warmed up, like 1400-1500 rpm. I'm sure the dealer would take care of it, but if there is a simple idle adjustment screw, I'd prefer to just take care of it myself. Anyone know? Thanks! Sent from my XT1096 using Tapatalk
Not sure if it's the same here, but look to see if there is the little rubber plug on the right side of the frame, just below the tank, should be the size of a pencil eraser. Useing a long small Phillips will do the trick. It does on the 5th gen.
I just searched it and found a thread pointing out that there is actually a black knob on the left side near the clutch slave cylinder. Thank you Honda for making this an easy adjustment! Sent from my XT1096 using Tapatalk
