Ignition switch swap to toggle?
Discussion in 'Mechanics Garage' started by MrBiLLyJAcK, Dec 13, 2010.
  1. MrBiLLyJAcK
    MrBiLLyJAcK New Member
    ETown
    Second post after successful first try....
    Is anyone aware how to remove the entire ignition to replace with simple toggle switch to power bike?
    No room for ignition and I don't plan on letting her out of my sight so no keys is ok with me.
    Thanks in advance :)
  2. crustyrider
    crustyrider New Member
    North Country, New York
    it should have a few bolts holding it in..... on the underside if it....? no keys for said beasty?
  3. creaky
    creaky New Member
    Do you have a wiring diagram?
  4. MrBiLLyJAcK
    ETown
    Wiring diagram yes. Keys yes. Two ignitions with keys, yes. I have it off the bike that was no problem.
    It's more " can you wire it without the ignition ? "
    There is no room on the bike to mount it anywhere besides the upper triple, which has no room, with a Koso gauge on it :) wiring help for that would be appreciated too. Holy vague instruction and wiring! Yikes !
