Ignition Timing
Discussion in 'Mechanics Garage' started by J_Wzk, Sep 4, 2023.
  1. J_Wzk
    J_Wzk New Member
    Minnesota
    I have a 1999 VFR800 and am having some troubles with the firing timing. The camshafts line up at there correct mark yet at the F mark on timing gear, the bike doesn't fire at that point. I checked with a timing light. I have tried different coils and didn't seem to change much.
    Any suggestions and/or help would be greatly appreciated.
    Does the crank positioning sensor test OK?
    Have the cams been removed and reinstalled recently?
  3. J_Wzk
    J_Wzk New Member
    Minnesota
    How do I preform that test? And yes I have removed them to fix valve clearance but reinstalled them correctly following the manuals instructions.
  4. squirrelman
    just how far off the F mark is it ? does the bike run ? does the timing advance correctly to the MAX mark ?
  5. J_Wzk
    J_Wzk New Member
    Minnesota
    it fires at idle on the cam timing mark and yes it runs. after revving to about 5 thou it makes its way to the max mark.
  6. squirrelman
    thats normal, AOK.
  7. J_Wzk
    J_Wzk New Member
    Minnesota
    Thank you for the help kind squirrelman
