I'm confused why my bike is suddenly leaning extremely far
Discussion in '6th Generation 2002-2013' started by wa.stewy, May 16, 2020.
  1. wa.stewy
    wa.stewy New Member
    Bremerton
    I got on my bike at the store, with the kickstand still down, and it felt like something slipped and the bike tilted further toward the left side. I didn't really think too much of it at the time because the ground was wet and I was on a slight hill. When I got home is when I noticed something was wrong. The picture doesn't do the justice of how far this poor thing is leaning against the kickstand. I've looked around and can't really figure out what's changed. If anyone has any ideas I would be grateful.
  2. jstehman
    jstehman New Member
    Hard to tell if you are missing the one bolt that usually goes missing. The front one in the pic[​IMG]
    Sent from my SM-N950U using Tapatalk
    wa.stewy likes this.
  3. rhoderage
    rhoderage New Member
    Nova Scotia
    34468 Randy, wa.stewy and jstehman like this.
  4. raYzerman
    raYzerman Member
    Millgrove, ON
    Yep, looks like the kickstand is going forward more than it should, your one pic showed the foot not flat to the ground.
  5. wa.stewy
    wa.stewy New Member
    Bremerton
    You guys are awesome, thank you!!
    It felt like that hole was supposed to have a bolt in it (strange that is not uncommon, unless maybe it just gets sheered?) but in my service manual I couldn't find the kickstand to confirm. I really appreciate the quick help everyone.
    Sent from my SM-A205U using Tapatalk
  6. 34468 Randy
    Yes. This has been reported by several here and the 6th gen at least, is infamous for this. I have checked mine many times over the years I have owned it, and mine has never been loose but so many have found out, sometimes the hard way, that these bolts tend to disappear.
    Kuddos to rhoderage for not only posting the problem, but also a link to replace what is lost. I wonder it the Honda Factory had someone on the line over a period of time who screwed up. Maybe no lock washer or something.
  7. wa.stewy
    wa.stewy New Member
    Bremerton
    Kudos indeed. The part has been ordered now.
    It looked wrong to me for the kickstand's mounting piece to be putting pressure on the shift levers rod sheath, or spool or whatever you want to call it. It felt like that would eventually cause issues to the clutch plates (really not that familiar with automotive construction, but still seemed unnecessary sheer pressure to that component).
  8. VFR4Lee
    VFR4Lee Member
    Reseda / LA
    The infamous Harley bolt.
    I don't know why else it would seem prone to falling out. :Yo:
  9. sarge383
    sarge383 New Member
    blaine wa
    Blue loctite when it goes back together. Then add it to the preride check list.
    wiremanjon and wa.stewy like this.
  10. Camp
    Camp New Member
    Easton, PA
    Doing the parking spot pivot on the stand will do it too. Ttust me.
