Im Forked!
Discussion in 'Mechanics Garage' started by maintman75, Feb 27, 2011.
  1. maintman75
    maintman75 New Member
    Clerwater,Fl.
    I have Bent forks on my 2004. I cant find any good used ones and cant afford new ones! is there any other honda with the same forks or pre 2002 forks that will fit my 2004??? Thanx Mark
  2. bitterpil
    bitterpil New Member
    Northern Virginia
    Keep looking they will show up . They come in spurts.
  3. melmsrt4
    melmsrt4 New Member
    Menifee, CA
    Don't know if length will work, but you might want to try Honda CBR 929 or 954. They are the same diameter.
  4. volks6000
    volks6000 New Member
    Jacksonville , Florida
  5. Fazer1Sniper
    Fazer1Sniper New Member
    Good time to look into the inverted fork mod:rockon:
  6. squirrelman
    If you've bent the forks, you've damaged the headset bearings too, so replace them with OEM, not allballs.
