I'm sick of my elbows
Discussion in '5th Generation 1998-2001' started by Wiggo, Jun 16, 2019.
  1. Wiggo
    Wiggo New Member
    Ok, so I love my VFR, but for one thing: it has a massive blind spot. No matter how I position them, all I can see in the mirrors is my own bloody elbows. I need mirrors with longer stems, maybe a couple of inches longer. Am I alone in this, or has anyone found a solution?
  2. fink
    fink Member
    Push your mirrors forward a bit that will make some difference. you will never find a bike with fairing mounted mirrors where you will never see parts of your arms. If you do let us know. Move your head as well when looking
    Bubba Utah likes this.
  3. Wiggo
    Wiggo New Member
    Cheers, Fink, but I have wide shoulders and it doesn't matter what contortions I go through short of climbing off one side to look in the opposite mirror, I can see absolutely bugger all.
  4. Norse
    Norse New Member
    Denmark
    You can get mirror extenders that move them a bit further out. But if you are not sure that is what you want, you can just throw a spacer between the mirror and the fairing and see if you like it.
    Some people also like those small wide angle mirrors you can stick in the corner of the original mirror. Those should take care of blind spots pretty well
  5. Wiggo
    Wiggo New Member
    Mystery (possibly) solved! It seems the mirrors from a Kawasaki ER6-F (2012-2017) fit on the Honda mounts perfectly and are a good 2-2½" wider. I just need to swap them back before she gets home from work...
    marriedman and Thumbs like this.
  6. Allyance
    Allyance Member
    Sweden
    East Bay, California
    I use a small circular wide angle mirrors in the corners of each mirror to check my blind spots. I don’t ride the freeways very often, I stick to two lane back roads.
  7. marriedman
    marriedman New Member
    Dayton, OH
    Be sure and post some pictures of how they look on the bike!
  8. stubbs
    stubbs New Member
    That’d be awesome, try it and post pics! I also got tired of seeing my arms, so I found some machined delrin spacer blocks on eBay and had them shipped from Canada. They weren’t cheap at $45 or so and aren’t super pretty with my rubber sleeve mirrors but it definitely helps.
    I think it’d look a lot better with the 00-01 mirrors and spacers or the Kawasaki mirrors. If the Kawi mirrors are capable of folding and still maintaining their position, even better!
    https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/132214459846
  9. Wiggo
    Wiggo New Member
    I'll post some pics later, but these are what I ordered: https://www.ebay.com/itm/Black-Rear...SX-2011-2012-ER6F-ER-6F-09-12-10/201041035987
    Throw away the base, but the arms mount straight to the Honda ones using the same bolts and washers
    stubbs likes this.
  10. Wiggo
    Wiggo New Member
    Okey dokey, so I went and stole my other half's mirrors while she was at work. First up, here are the standard 2000 issue Gen 5 Honda mirrors:
    They're 900mm wide, or 2 13/64 cubic bushels to our American friends.
    Mr Kawasaki's 2015 ER6-F's finest, however, come in at 1015mm (4½" wider)...
    VFRIRL and Deadsmiley like this.
  11. Deadsmiley
    Deadsmiley Insider
    Bowling Green, KY
    Believe me. I would much rather we go to the metric system and stop using the cubic bushel system. ;)
  12. adk_finn
    adk_finn New Member
    Vermont
    Those mirrors look pretty good, nice discovery. I expect a used set is a cheap solution for those of us wide shouldered riders.
    When I swapped to EMGO 2001 mirrors (to dump the saggy condom style mirrors on my '98) I found that they seem a little bit wider and I now have less issues seeing past my shoulders/arms. I didn't measure so it could just be that I have them set up better?... but the improvement (admittedly minor) was noticeable.
  13. Wiggo
    Wiggo New Member
    Sheesh! They're only $20 new on Ebay...
    adk_finn likes this.
  14. adk_finn
    adk_finn New Member
    Vermont
    That is a great price!
  15. Wiggo
    Wiggo New Member
    I lied. $22.69, including shipping.
  16. DaHose
    DaHose New Member
    Napa, CA.
  17. VFRIRL
    VFRIRL New Member
    Ireland
    Ireland
    I can't find any er6 f mirrors 12-17 on ebay, plenty for the older model 09-12 though.
    have you got an ebay link? I need to replace the condom mirrors on my 98 and was looking at mirror extenders too so these mirrors you found would kill 2 birds with one stone for me, good find.
  18. stubbs
    stubbs New Member
    VFRIRL likes this.
  19. VFRIRL
    VFRIRL New Member
    Ireland
    Ireland
  20. stubbs
    stubbs New Member
    VFRIRL likes this.
