I'm sure someone will point out that I missed it with search, but...
Discussion in '3rd & 4th Generation 1990-1997' started by bakayara, Nov 29, 2009.
  1. bakayara
    bakayara New Member
    Dallas(-ish), TX
    I can't find anything about how to adjust the read shock on a 4th gen ('97)...
    Any suggestions on what to set it to are welcome, tho I'll probably fiddle with it once I know how... I'm 6'4", 160#, 42 years old and have ridden off & on my whole life, only ride solo and I'd describe my riding as semi-sport - it's been a few years (OK, 10 or more) since I've needed duct tape on my jeans knees - but I like to have a spirited run down the Texas farm-to-market roads (very well maintained, semi-deserted strips of twisty fun asphalt - highly recommended if you get the chance :thumbsup:)
    Thanx, guys...
    You're right about those farm roads, especially down in the hill country around Austin--well maintained and uncrowded !!
    There is a small hole in the gen 4 frame on the left side, and the shock preload can be adjusted using a 10mm socket. There is red scale for reference to indicate the setting, and maybe ( i forgot) a detent click every half turn........
    Don't loose the setting you have now that's been working: turn adjuster counterclockwise and note number of clicks or number of turns, then return to base setting and incease or decrease as desired.
  3. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    Measure the sag (do a search) and adjust the preload (in the manual). You'll need a tool from the provided toolkit to adjust the preload adjuster which is at the top of the shock. Move clockwise to increase preload and counter clockwise to lessen the preload. I aim for 35mm rear sag. The more preload, the stiffer the ride (not the spring). The less prelead (more sag) the softer the ride.
  4. squirrelman
    IT'S a '97 Jaim, not like your bike, no collar......it has a more sophisticated means of preload adjustment by hydraulic pressure, which Honda later abandoned to save money.
  5. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    Yeah, I saw your post after I posted (but was too lazy to edit). Man, that setup sounds much better than the 5th gen setup.
  6. squirrelman
    It is way easier to use and, since few (none that i know of) other bikes have had it, it used to be one of those details that made Hondas "special," like the gear-driven cams they dropped also.
  7. jaimev34
    jaimev34 New Member
    Oceanside, Ca
    Freakin' Honda. How much money does the "new" system really save?
