Indicator problem
Discussion in '1st & 2nd Generation 1983-1989' started by petethepilot69, May 4, 2013.
  1. petethepilot69
    petethepilot69 New Member
    Hi guys
    I have a 1st Gen RC24 (fg) '86 model VFR and am in the prcess of getting her fot for the road....
    Ive put the bike back together after stripping all the panels off to replace with some new ish 1s and now have the problem that the Left indicator stays on as if wired to the Sidelight as it goes out when the handlebar switch is turned out?
    After checking all the woring and replacing with new higher quality wire it still stays on?
    Im assuming maybe the relay is faulty?
    Question s
    Where is the relay situated as I dont seem to be able to find it and ...
    Has anyone else had this problem, If so what was the cure?
    TIA
    Pete
  2. artee
    artee New Member
    Rochdale,
    Hi
    First of all..
    Is it a UK bike? If not some bikes especialy US models have running lights upfront.
    Have a look at the wiring where the indicator plugs into the loom. Are there two or three wires available to plug into.
    As for the relay.. remove the left infill panel and the relay should be near where the top screw which you have just removed. It is close to number 16 when you remove the panel 31
    http://www.lingshondaparts.com/hond...ck_01=13ML7G41&block_02=F__3300&block_03=5721
    Come and visit a UK based Vfr forum.
    Honda VFR Club - Powered by vBulletin
    Roger
