Inlet & Exhaust Valve dimensions ?
Discussion in '5th Generation 1998-2001' started by Mohawk, Dec 15, 2011.
  1. Mohawk
    Mohawk New Member
    Bristol
    Hi All,
    Does anyone know the VFR800Fi Valves dimensions ? Don't seem to come up readily.
    I assume they are the same as the RC45, but again I can't seem to find that info !
    What I'm after is,
    Inlet & Exhaust
    head diameter =
    stem diameter =
    overall length =
    Cheers
    Mohawk.
  2. ignoreance
    ignoreance New Member
    Santa Clarita
  3. TOE CUTTER
    The manual only lists the stem O.D, intake @ 4.475-4.490 and exhaust @ 4.465-4.480. I cross referenced the valves from the gen 5 and gen 6 in an effort to see if Kibble White offered info from another application and they are unique to the two bikes. Sorry.
  4. Mohawk
    Mohawk New Member
    Bristol
    Thanks Toe Cutter, that was pretty much where I ended up ! I'm fairly sure they are the same size as the RC45, as the heads are stright swaps, but I can't even find the RC45 info !
    I've just picked up a cheap crashed bike engine, that broke a couple of the engine mounts (why its cheap), so will strip the heads off & see if I can do a bit of tuning work. I reckon that with some reworked cams & a bit of gas flowing & matching I can squeeze another 10-20HP out of this baby. The standard UK spec RC45 with a slightly smaller engine (749cc) was good for 118-120RWHP & I've got 102RWHP at the mo. The basic differences I can find are cam duration & lift.
    So if I can afford it in the spring, I'll get the spare cams reground to RC45 spec & see what happens :wink:
    Might even entertain upgrading the throttle bodies to a larger size, but that's a whole other project, maybe one for next winter !
  5. Mohawk
    Mohawk New Member
    Bristol
    Found the info for RC45, as follows;-
    Inlet & Exhaust
    head diameter = in 29 - ex 24.5 (Looks like the head won't take anything bigger !)
    stem diameter = 4.5mm (guide id, in VFR manual)
    overall length = TBC
    No exotic replacements avilable, so STD it must be.
