inline fuel filter and fuel strainer
Discussion in 'Mechanics Garage' started by duncan.VF500, Dec 12, 2018.
  1. duncan.VF500
    duncan.VF500 New Member
    hey, so I just bought an 86 VF500F inceptor, the tank was full of rust. I took off the tank and removed the petcock unfortunately in the process I just massacred the fuel strainer/screen only to find out that Honda no longer makes this part and its impossible to find. Considering the 86 has no other filter between the petcock and the carbs I was wondering if anyone knew if it would be sufficient enough to put in 2 inline filters after the Y?
    side question: is it possible to gravity bleed the clutch when there is already air in the lines?
    any help would be greatly appreciated, thanks!
  2. Bat-1
    Bat-1 New Member
    Aiken, SC
    Thoroughly clean and line the tank (I've had great results with the KBS 52000 kit. It takes a couple days to dry but you'll never have to worry about rust again).
    After that an in-line filter should serve at least as well as the missing strainer. Get the clear cased ones and you can keep an eye on things. I see no reason why this wouldn't work at least as well as stock strainer.
    Not sure I understand the clutch bleeding question. Why would this be a problem? Aren't you always bleeding the clutch with air in it? Or why bleed it?
    As long as pressure is being applied to a closed system the lighter air should be forced out at the bleeders. I've had times on brake lines where it's almost all air and I've used a syringe to force fluid into the system.
  3. Scouser
    Scouser New Member
    Carlisle Ontario Canada
    Canadian Tire sell a clear glass type that will work. I just put one in line. (Rebuilding most of everything) I'm in the same process of Tank cleaning using CLR then Diesel fuel. Still cleaning out a lot of rust.
  4. Diving Pete
    as a FYI, the glass filters will only stop the big bits - the other stuff still gets through. Rusty tanks put an incredible amount of crap into the whole fuel system.
  5. Nickle
    Nickle New Member
    Hello to all on the forum.
    I have recently bought a 1985 VF500F2 and am looking for help.
    Almost 2 years on from the above posts and a new fuel tap filter/screen still seems impossible to find.
    Does anyone know of a source or a suitable 1/2'' in line filter ?
    Help would be appreciated
  6. raYzerman
    raYzerman Member
    Millgrove, ON
    Most fuel filters have a 5/16" nipple... should be more than enough flow. Wondering why you want 1/2".... should be able to find 5/16" just about anywhere.
  7. Nickle
    Nickle New Member
    The hose from the fuel tap to the carbs is 1/2'' before it divides into two hoses to feed the carbs.
  8. squirrelman
    you'll definitely need to scrub clean the small filters just above the float needle seats as rust will accumulate there and stop or reduce fuel flow.
