Installed VFRNess and blew fuse
Discussion in '3rd & 4th Generation 1990-1997' started by cronos68, Jun 6, 2014.
  1. cronos68
    cronos68 New Member
    nyc
    I previously posted a burnt connection at relay.
    VFR 750 4th gen
    Installed new harness and blew the 30 amp on relay. I thought i followed correctly.
    On old connector (going into relay) red wire was where melt took place.
    What i did> 1:connected vfrness red to red/white at relay
    2: cut tabs out of remaining 3 wires (at relay) at butted them together with 3 (new/supplied) wire extensions provided with kit.
    3: turn key and lights up, hit started and blew 30 amp at relay.
    All else seemed straight forward swap.
    Please see pictures.
    Greg
  2. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    If someone doesn't help you out here, reach out to tightwad at wiremybike. He was always really helpful to me in the past, and since he created the VFRness, he should know. I, for one, cannot help.
  3. Allyance
    Allyance Member
    Germany
    East Bay, California
    Here is schematic from a 2003, should be same basic circuitry.
    Sounds like you hooked switch to ground instead of coil on relay or coil of relay is shorted to ground.
