Installing ABS system on 2000 model
Discussion in 'Mechanics Garage' started by yotam, Aug 19, 2024.
  1. yotam
    yotam New Member
    Israel
    Hi,
    Did anyone tried to install ABS from new generation on 2000 model?
    Any idea/thought?
  2. Terry Smith
    Nothing is impossible, and the ABS system is just a control module, two ABS pumps and two wheel speed sensors and tone wheels plus wiring and hoses. The trick will be integrating those onto a bike that was never designed for it.
    The tone wheels are probably straightforward, and the speed sensor is integrated into the right front calliper mount on a 6th gen, maybe that is interchangable with the calliper bracket on a 5th gen? And the rear sensor mounts on the brake bracket which also might be interchangeable?
    There's a lot of empty space on the left front subframe of a 6th gen where the ABS module lives and space elsewhere for the pumps. Not sure if the same is true on a 5th gen.
  3. squirrelman
    nearly impo$$ible, not worth the agro, forget it.:blinky: in theory, if you practice hard braking skills often, u could do almost as well as ABS.
    great if u could do it cuz ridin in rain and braking may scare some riders.
    do moto GP or WSB riders have ABS ?
  4. NorcalBoy
    Save $50k and just buy a Y2k for $2500.
    34468 Randy likes this.
