Instrument lights
Discussion in '3rd & 4th Generation 1990-1997' started by VFRVogt, Apr 7, 2023.
  1. VFRVogt
    VFRVogt New Member
    Atlanta
    Has anyone replaced a lightbulb within the instrument panel?
    I’ve got one bulb that’s out and I already have the front panels, etc. off so why not…
    Do I approach it from the back of the unit to get to it, or do I have to tear it apart from the front, taking each instrument out to get inside?
    Any tips would be appreciated.
  2. hondaman219
    hondaman219 New Member
    maine usa
    bulbs just push into the back of the panel. Each bulb has its own socket. Just pull it out and replace bulbs.
  3. VFRVogt
    VFRVogt New Member
    Atlanta
    So just pull the rubber boot in other words from the backside shown?
    Correct. And a great time to wire in a USB charging socket.
    RogueRC24 and rc24dk like this.
  5. bmart
    bmart Insider
    Charlotte, NC
    RogueRC24 likes this.
  6. 102dalz
    102dalz New Member
    Little Rock, AR
    Just did this on my HawkGT...haven't tackled the VFR yet. Have all the bulbs though, as the Hawk only has 5 indicators & 2 instrument bulbs.
    How hard is it to get at the back of the VFR instrument cluster?
    Cap, where'd you add your charging socket?
  7. VFRVogt
    VFRVogt New Member
    Atlanta
    It’s not difficult but does take some time to get to because of the plastics, etc.
  8. 102dalz
    102dalz New Member
    Little Rock, AR
    My Hawk uses a few T5 bulbs...does the VFR use those?
    @102dalz - I cut a brown wire to one of the back illumination bulb sockets and crimped on a male & female bullet connector with the thin USB charger red wire incorporated in one of the crimps. Then ran the charger ground with an eyelet to a bolt. I can snap a pic if you like, I have the upper cowl off my 95 right now.
  10. 102dalz
    102dalz New Member
    Little Rock, AR
    Cap,
    Please...please snap & pic & post or PM?
    REALLY curious if you just ran wiring or a "box" with ports?
    Thanks in advance
    I couldn't get to the front of my 95 last night for a clear shot, too many projects going on to move everything. But this is the style I put on every bike, been using them for years with zero issues. This one will be going on the 92 VFR that's on my lift.
    eBay special. I mount them behind the dash and zip-ty the module to the wire harness out of sight. The module is not very big and can tuck in somewhere easily. The lead to the USB port (w/ water proof cap) is nice and long and I run it up to the back of the ignition switch usually.
    Hope that helps.
  12. 102dalz
    102dalz New Member
    Little Rock, AR
    Perfect....thanks for your superior resources.
  13. RogueRC24
    Ohh hell yeah, nice stuff on this thread!
  14. Pettefar
    Pettefar Insider
    Ireland
    Near Drogheda, Ireland
    I recently renewed the instrument lights on my ‘93 VRF750FP using 4 x T10 LED bulbs. Such a lovely difference. I used YONGMING T10 501 LED bulbs from Amazon.co.uk.
