Interchange Gas Tanks
Discussion in '1st & 2nd Generation 1983-1989' started by sellersis, Jul 8, 2009.
  1. sellersis
    sellersis New Member
    I found a decent gas tank on ebay but one of you turds outbid me. Is there any other tank that will fit the VF500?
  2. TOE CUTTER
    Terds?
    Terds???????????I think 82 vf 1000 tank may fit.
  3. slowbird
    slowbird Member
    Toronto, Ontario.
    Really? A Larger tank will fit?!?
  4. volks6000
    volks6000 New Member
    Jacksonville , Florida
  5. gunnarf06
    gunnarf06 New Member
    Hafnarfjordur
  6. gunnarf06
    Hafnarfjordur
  7. gunnarf06
    Hafnarfjordur
  8. slowbird
    slowbird Member
    Toronto, Ontario.
  9. great white
    great white New Member
    way to make friends there bucky....:thumbsup:
  10. slowbird
    slowbird Member
    Toronto, Ontario.
    hahahahaha....
  11. crustyrider
    crustyrider New Member
    North Country, New York
    I'm sure he meant that in the most brotherly, best friend competative nature, chug on the shoulder kinda way
    :crazy:
  12. sellersis
    Exactly, Crusty! :thumbsup:
    Forgot that there may be people here with no sense of humor.:rolleyes:
  13. TOE CUTTER
    Vfrd
    Thats it.......I quit......going to VFRD......how did that 82 1000 tank fit?
    :biggrin:
  14. great white
    Interesting enough, much the same could be said about the response to my post....
    :tongue:
    Dang internet.....:wink:
  15. sellersis
    Do you guys think it would be wise to try to fix the tank I have instead of buying another one? It's rusted through in two places, one on either side of the tank. Pinholes really, very tiny. Should be easy to fix.
  16. gunnarf06
    Hafnarfjordur
    Holes are easy to fix but
    Hey
    It is easy to fix the holes but it is the rust that you really need to stop also.Maybe the hole is 1-2mm but if the rust is over 10 cm area then I would try to find another tank.
    Best regards
    Gunnar
  17. eddie cap
    eddie cap New Member
    Valley Forge, Pa
    I would also suggest a new tank,however if you are up against the wall this is what you
    can do to minimize the rust.First remove tank from bike and drain all fuel out of it. Take somewhere around 16 oz. of small machine screws,nuts , sheet metal screws and other misc.small sharp clean objects and put them into the tank with a few ozs. of light oil,like
    WD-40. With this mixture take the tank and start shaking it so that you are agitating
    the hardware inside the tank ,what you are doing is removing the rust.
    Continue to do this until you are tired,then add about a quart of Kerosene or
    paint brush cleaner and shake a little,drain out the mixture and repeat until the mixture
    comes out clean, that at least should do it for the rust inside. For the outside I would
    use fiberglass to fill the holes. You can do this or just buy a new tank and forget about this mess!!! eddie
  18. RHawkman
    RHawkman New Member
    Seminole, Oklahoma
    So eddie, i just put some WD-40 and about a pound of metal in my tank. that should prevent it from ever rusting, right? ;-) Gonna take the bike over a few jumps to slosh it all around.
  19. eddie cap
    Valley Forge, Pa
    Well let me say this Hawk,if my ability to write insrtuctions is so lacking
    that you interpreted my words as you stated, I think I will go hang myself.
    But really, I knew there would be many such comments as yours. The
    instructions that I wrote are not something that you would see in a metalurgy text book,but I would be willing to bet this method has been used
    more than once in many third world countries. regards eddie
  20. RHawkman
    RHawkman New Member
    Seminole, Oklahoma
    LOL, yeah, and it actually sounds like it would work pretty well. Sorry, I was attempting (weakly) to make a joke....ron
