Inverted forks on the 5th gen?
Discussion in '5th Generation 1998-2001' started by vfrweiser, Oct 7, 2012.
  1. vfrweiser
    vfrweiser New Member
    Phoenix, AZ
    Has anyone ever attempted, and scceeded, to put inverted forks on a 5th gen? If so, is this a good upgrade, say cost effective? Thanks for any feedback.
    Kane, 2000 VFR800FI, 40k and counting
  2. tinkerinWstuff
    Yes, it's been done.
    Good upgrade? Cost effective? That all depends on what you want to get from the upgrade. It won't have you winning races.
    It looks co as hell.
  3. silverbullet132
    silverbullet132 New Member
    Is it at all possible to swap on inverted forks and keep the linked brakes?
  4. tinkerinWstuff
    Everything's possible. I'm not sure if it could be done without custom machined caliper mounts
  5. tinkerinWstuff
    cue - linked brake haters, stage right......
  6. Rangerscott
    Rangerscott New Member
    Texas
    The best VFR with inverted forks that I've seen was a 6th gen with yellow R1 forks w/ brakes. Damn did it look good.
  7. DaHose
    DaHose New Member
    Napa, CA.
    If I was considering a fork swap, it would be the complete front end.
    Forks, triples, brakes, wheel, fender ..... everything.
    Is there a stock front end that would be "great" right out of the box? Almost EVERY front end I see that is "race ready" has no stock internals left in it. You may as well just buy some Ohlins forks and figure out how to make them work. Now THAT would be trick.
    Jose
  8. silverbullet132
    If I do ever go into swapping on a USD fork setup, keeping LBS, the forks would probably be fully built. Valves, springs, etc by either traxxion, racetech, or ohlins. Cheaper then buying a set of ohlins forks :)
  9. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    RC51 is the most common front end swap, plenty of threads here and vfrd about the details. Cost me less than $1K after reselling the OEM parts. There isn't an easy way to retain the linked brakes, but delinking them is pretty straightforward.
