Is it going to hurt?
Discussion in 'Mechanics Garage' started by Adonis, Dec 29, 2014.
  1. Adonis
    Adonis New Member
    Armstrong, British Columbia, Canada
    One of the pulse generators is crapped out on my daily driver. How bad is it to keep running my bike on 2 cylinders 20-30mins a day? (not necessarily everyday)
    It fires on all 4 first thing in the morning but loses spark on 1-3 within 5-10mins.
    Besides fouling plugs is it going to hurt anything to keep riding it few times a week? Just until I can get the part to fix it (2-4 weeks away).
  2. rjgti
    rjgti New Member
    regina sk
    fuel washed cyclinder walls come to mind, exhust damage due to unburnt fuel explodinging ing the hot exhust....hmm i will think of more.
    if it was my ride it would be parked
  3. Adonis
    Adonis New Member
    Well thats not good to hear… It's a catch 22 I'm in then, if I don't ride it into town I can't make money to fix it. :grey:
  4. rjgti
    rjgti New Member
    regina sk
    tough spot to be in, maybe someone on here has a spare for you
  5. Gms
    Gms New Member
    Greece
    Athens, Greece, Greece
    You can check the generator connector to see if there is any kind of heat damage or rust and also check the cdi connector.This could be also caused by a damaged wire on the generator loom.
  6. Adonis
    Adonis New Member
    All connections on my bike have been gone over 3 times + with a fine tooth comb (cleaned/repaired if needed). My "igniter spark units" (CDI) have also been gone over and everything resoldered.
    Its actually a wonder the bike was even working when I bought it a few weeks ago. Battery was almost bone dry and reading 11.6v with ignition On. connection from the alternator to regulator/rectifier was melted and fused together yet strong/steady 14.5 volts with bike running.
    Battery was removed, topped up with distilled water and placed on a "smart" charger for two days. Functioning as it should both volts and load test.
    Wiring from alternator to regulator/rectifier cleaned and repaired.
    The pulse generator died about a week ago. At first I was able to ride it into town no problem and it would eventually fail while running errands, So I would just let it sit for an hour or so and I could ride it home. But its been getting worse and now it fails within 5mins or so of starting the bike.
    I'm 100% confident the pulse generator to the 1-3 ignitor has failed.
    What I don't have is the hundred dollars needed to buy a used set off eBay. Nor any other transportation means while waiting the several weeks it will take for shipping from the US.
  7. Allyance
    Allyance Member
    Germany
    East Bay, California
    I have a spare set from an '83, anyone know if they are the same??
  8. jerritt
    jerritt New Member
    Toronto
    You should keep an eye on your oil the unburned fuel may seep past your rings and contaminate your oil
  9. Allyance
    Allyance Member
    Germany
    Will these work??
    [​IMG][​IMG]
    From my first bike which had about 3600 miles
  10. Adonis
    Adonis New Member
    Yes! the parts are identical..
  11. squirrelman
    Ally just saved your Canadian bacon ! :congratulatory:
  12. Adonis
    Adonis New Member
    Thankfully on the same coast line too!
  13. zoom-zoom
    zoom-zoom Member
    BC, Canada
    One of the best things about this forum, people helping people. You meet the nicest people on a Honda. :)
    Hope of everything works out and you get the bike back on the road sooner than later.
  14. Allyance
    Allyance Member
    Germany
    Send me private message with your address and I will send them out tomorrow. Use what you need and we can work it out later.
    Engine was running fine when I tore it down. Honda dealer had not installed cam chain tensioners properly, ended up buying a second bike at the time.
  15. Adonis
    Adonis New Member
    Thank You very very much! Will send pm right away.
  16. MichaelD
    MichaelD New Member
    Central Kansas
    Its so nice to see brother hood and kindness. Helping someone in need. My hats off to you Allyance.
  17. rjgti
    rjgti New Member
    regina sk
    i knew someone on here could help you out adonis, way to step up ally
  18. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    Good man, Allyance!
    Good luck getting your bike up & running Adonis.
  19. Allyance
    Allyance Member
    Germany
    Package on the way, good luck.
  20. Adonis
    Adonis New Member
    Got the new pulse generator installed tonight and OMG what a difference! They must of been giving a weak spark since I picked the bike up a month ago...
    Its pulls so much smoother now and should hopefully fix the extreme poor fuel milage I was getting before.
    Very happy for change. Shame its so dark and wet out! lol (I just did the pulser swap by flashlight under a dripping wet pine tree)
    Thank you once again Allyance - Just made my year!
