Is there a 3 row oil cooler that will fit a 4th GEN?
Discussion in '3rd & 4th Generation 1990-1997' started by rangemaster, May 25, 2009.
  1. rangemaster
    rangemaster New Member
    Albuquerque, New Mexico
    I commute here in Albuquerque and it can be 60 going to work in the morning and 100+ going home in the late afternoon. Do any of the earlier/later Honda 3 row oil coolers fit my '97?
    Thanks.
  2. safetypro10
    safetypro10 New Member
    Dallas, TX
    3 row cooler
    Yes, they will.
    Larry
  3. rangemaster
    Thanks Safety Pro. Any info on which generation (year) VFR 3 row cooler works? A buddy has a 2nd gen cooler but doesn't know if it'll go on my '97.
  4. safetypro10
    Dallas, TX
    Actually, any gen 3 row will work. Just unbolt from the lines and bolt to your lines. You may have to fab a mount as the 4th gen bolted with one bolt in the middle and earlier ones used 2 bolts, no biggie. It has been done many times.
    Larry
  5. dale-j
    dale-j New Member
    British Columbia, Canada
    I did the same thing on my 93, using a first gen CBR600 cooler - so you may find that other honda models work as well. The CBR cooler was not much bigger but mine had been damaged. Here's what I built to mount it from a piece of aluminum.
