Is your Vfr800 blowing fuses or killing regulators
Discussion in '5th Generation 1998-2001' started by csjea, May 17, 2004.
  1. csjea
    csjea New Member
    IF YOUR VFR800(MAY WORK WITH OTHER MODELS) is burning up new voltage regulators quicker than you can replace them, you NEED to purchase this item. This FIX kit was designed to replace the factory charging system with one that is more stable and more reliable. Installation is simple and making the wiring harness is also easily done(I can make the harness for you for an extra twenty dollars, this way all you will have to do plug it in and ride). It took me about 30 minutes from start to finish. Included it this package is a schematic, connectors, electrical tape, FULL easy to understand installation instructions, and a voltage regulator/rectifier. Troubleshooting info and tech support is also provided. I can also make this work for some other models of bikes as well if yoy e-mail me an electrical schematic. E-mail me at csjea@charter.net for ANY questions you may have. E-mails will be answered after 5pm EST.
    The price for this kit is $169.99 and is payable by Paypal, Money Order, or Check.
  2. vfracer
    vfracer New Member
    New Jersey
    Re: Is your Vfr800 blowing fuses or killing regula
    Hi,
    Is this for 98- 99 VFR's?
    You dont have to change the stator?
    Thanks for the post.
    VFR Steve
  3. csjea
    csjea New Member
    yes it is designed specifically for 98-02 vfr800 although i can make them for other bikes. the stator dosent have to be changed unless it is going bad but in 90% of charging problems this is not the case. the kit i am selling is basically a "retrofit" with a few modifications. since i have fitted my 98 vfr800 i have experienced no more problems.
  4. Motomaj
    Motomaj New Member
    utah
    so...after mucho confusion about login...here goes. i have a bad rec/reg. just found this out yesterday while i was at the ktm shop. i like the wrench there. anyway he checked the the battery...full charge..well as charged as coluld be. after checking the system he determined that it was in fact the rec/reg..(one in the same?) do i tell the shop to forget the order for the new one???? will this happen again??? i replaced tghe batterey once..guess that wasn't the problem... please get back ..it appears that you have the solution....801 451 5206....paul
  5. vfracer
    vfracer New Member
    New Jersey
    Hello,
    In my case I have not had a problem since I installed the newer version of the R/R...AZ motorsports.
    You can purchase the item and install yourself.
    Best thing I found to to is read the threads in this site.
    I think its best to change if you are having any problem's charging. Why take the chance . See my post what I went thru.....VFRSteve
  6. Motomaj
    Motomaj New Member
    utah
    ??? hi....what's your address so i can send a check. i'll go ahead and get the harness also. 189 right? thanks amigo...paul
  7. Motomaj
    Motomaj New Member
    utah
    >:( ok 190..forgoto the .99!!!
  8. Motomaj
    Motomaj New Member
    utah
    >:( well i guess this thread is dead. i went and got a new rec/reg. i hope this solves this problem. love the bike.
