It's my turn for a stator and regulator/rectifier change.
Discussion in '6th Generation 2002-2013' started by mofo, Jan 17, 2017.
  1. mofo
    mofo New Member
    Orange County Ca.
    Would like to find out if anyone has a part number you can share for both, r/r and stator?
    I looked on revzilla and they want $125.63 for r/r/ $196.18 for the stator and $10.34 for the gasket. This are, as far as I know OEM parts.
    The same parts on amazon cost $74.93 for the r/r, and $132.49 for stator. These parts are NOT OEM, but both parts and seller have good reviews.
    https://www.amazon.com/ElectroSport...coding=UTF8&psc=1&refRID=55BVD3XC5N6QC2RKS04C
    https://www.amazon.com/ElectroSport...coding=UTF8&psc=1&refRID=FG74W0BM6H7T8AP6HMCG
    I'm open to suggestions and advice. Thank you.
  2. Allyance
    Allyance Insider
    East Bay, California
    Check with Roadstercycle.com, excellent reputation.
  3. 34468 Randy
    My aftermarket stator only lasted two years. That was only about 15, or so thousand miles. Mind you, that was two hard heavy rides through Nevada and onward. When it went the second time, I returned to OEM. Those prices look pretty decent to me.
  4. RVFR
    For the stator, for some reason I'm leaning towards the oem one, now RRs, for some reason yet to be known, lol, I wouldn't use an oem one. the after market Stators I've seen look cheaply made compared to the oem version. if you where to find out who Honda contracted out to build them maybe I'd go that route.
  5. OOTV
    OOTV Insider
    Was it Revzilla or Partzilla that you went to? The latter is where I get most of my OEM parts.
  6. duccmann
    CandyredRC46 schooled me and went for the sh847 from roadstercycle, plus the guy
    (can't remember his name) is awesome and makes them to order.
    If relocating like I did he will make longer wires for you. Still have my oem stator 40,000+ miles
    Good luck
  7. ridervfr
    Belgium
    OEM stator, aftermarket r/rs way to go. Jack at roadstar will hook you up. I can remember his name cause that was the name of my old Boston Terrier. ; )
  8. Badbilly
    Oem r/r? Lol
  9. vegaquark
    vegaquark New Member
    Spain
    Spain
    OEM is a big NOPE. Get a propper mosfet shunt (fh012aa, fa020aa, etc) or better a series one (sh847)
    Lots of info on the net on this particular subject. I've personally mounted a fh012ab from a triumph with oem stator with no problems at all. Maybe the stator is not on its best shape but works fine for now.
  10. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    OEM stator = Good
    OEM rr = Trash
    Electrosport anything = Trash
    FH020 / SH847 = Good
    www.Roadstercycle.com = Good
  11. mofo
    mofo New Member
    Orange County Ca.
    Sorry, it was Partzilla that I checked. I noticed they list A VFR 800 AC, and a VFR 800A AC? I've never seen it like that before.
  12. mofo
    mofo New Member
    Orange County Ca.
    Good grief brother. At first you were speaking gibberish to me, but now that I see the roadster website I know what you mean.
  13. mofo
    mofo New Member
    Orange County Ca.
    Mosfet: No clue what that means, but I sure would appreciate some education.
  14. Allyance
    Allyance Insider
    "metal–oxide–semiconductor field-effect transistor"
    A better type of transister used to regulate voltages.
    Go to roadstercycle.com, he has a important warning about e-bay fakes.
    The alternator (stator) generates AC voltages in direct relationship to RPM.
    The R/R converts the AC to DC and regulates output to the charging circuit.
  15. mofo
    mofo New Member
    Orange County Ca.
    Thanks Allyance. I learned something new today.
  16. duccmann
    Since going with the sh847 and relocating it, even on the hottest summer days here in LA, cool to the touch.
    Also cut off the connector which should no signs of failing and soldered it.
  17. mello dude
    Ditto....
    Although the series 847 is huge....You have to find a place to mount it...
  18. mofo
    mofo New Member
    Orange County Ca.
    Spoke with Jack at roadstercycle last night, he recommends I go with his "super kit" since I don't want to relocate it. Now i'm seriously considering a new place for it like duccmann suggested.
  19. duccmann
    It's pretty tang big, just made two brackets for my top box and voilà---a new home out in all the air it needs.
    Cool guy huh?
  20. mofo
    mofo New Member
    Orange County Ca.
    Very cool guy indeed.
