Jack/Lift Recommendation for 5th Gen?
Discussion in '5th Generation 1998-2001' started by Joel Brown, Jul 16, 2020.
  1. Joel Brown
    Joel Brown New Member
    Hope someone can help.
    I have a '98 and want to get a lift/jack for it. There are so many, I'm wondering if there's "one" I should get (thinking like... is the oil pan odd or does the center-stand interfere with some brands?) Or, is there one that will let me keep the fairings on (if I'm working on chain/tires/brakes/etc.)?
    I'm 99.9 % certain, I just get the one I think looks-good but, thought I'd see what the group thinks?
    Thanks, in advance. ~ Joel
  2. raYzerman
    raYzerman Member
    Millgrove, ON
    Get the flat red one, seriously..... make a block of wood/plywood to fit if fairings interfere, lift on oil pans or headers while bike is on the centerstand. Otherwise, get bike stands or an ABBA.
  3. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    I have the combination front lift stand from Pitbull, and the Harbor Freight motorcycle lift. Both work well,
    and serve different functions. I don't have a rear lift since I've found the centerstand works okay for
    the times I've needed to work on the rear.
  4. comradeQuestion
    comradeQuestion New Member
    Oregon
    I recently bought an ABBA stand and really like it. I got all the primo add-ons as well, they call it "Superbike Package 3". This one comes with casters so that you can roll the bike around in the garage with it completely in the air. The bike feels stable enough when on the lift even though I was a little wary of it at first. I had the entire front end off and swapped in F4i forks in 6th gen triples and did head bearings at the same time. I was careful not to push on the bike too hard, but that didn't hinder my work at all. The bike will twist left to right in the stand, and the stand will flex a little bit. This is what had me worried at first, but I've done all this work on the bike and its been solid the whole time. I am confident in it now, but still careful when working on the bike.
    My only other experience with stands has been with rear stands and center stands. The main reason I bought the ABBA stand is because I wanted to do this front end swap without jerry rigging something to prop up the front while on the center stand, and I don't like the idea of putting jacks underneath the headers. I also like that you can use the same stand with different bikes. You just need to buy the bike specific pin set from them. It packs up really small, so would be easy to take to a trackday and will allow you to remove both wheels at the same time (even with no center stand).
  5. iLikeThat
    iLikeThat New Member
    Norway
    I also have the ABBA sky-lift, perfect for working on bikes, works for most bikes with the specific adapters. As previous poster said, a bit of flex side to side, but it is completely safe to stand on the bike when using it. The only thing to be wary off is when putting the bike on/off the lift, can be a bit tricky.
    Had the whole front and swing arm off as well on my ninja 636.[​IMG]
  6. RllwJoe
    RllwJoe Insider
  7. Diving Pete
    If you have a centre stand then arguably you don't need a lift !
    Don't get me wrong, I have 9 stands including the abba skylift but why buy one if you don't need to?
    The centre stand on my 800 is used for 90% of tasks. the others just get a front stand added.
    So in answer - maybe a front stand could be useful for you, however I have removed the front wheels and forks whilst on the centre stand. Just need to strap down the back.
  8. Diving Pete
    if you are looking for a lift then the Skylift does get my recommendation - but its not cheap.
  9. vikingGoalie
    vikingGoalie New Member
  10. iLikeThat
    Norway
    Looks like it would be usable for bikes with frames under the engine. For example Harleys or something. Inconvenient for something like a modern bike/sport bike.
    You get what you pay for
  11. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    My step-son has one of the HF lifts similar to that for use with his Harley, and friends'
    Harleys. It works fine, but won't work worth a hoot without a fairly flat area on the bottom
    of the bike to sit on. VFR's don't have that flat surface.
  12. vikingGoalie
    while true that you can't lift directly with it. here's an example of what one person did with that lift.
  13. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Hmm, that's definitely thinking outside the box. Good solution.
    But the regular HF motorcycle lift table isn't that much more and works well.
  14. vikingGoalie
    Hmm at least at my HF, the motorcycle lift with table is $449 which is over twice the $199 for this lift. and I am a bit cheap at times ;)
    pi-on likes this.
  15. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    But you can catch them on sale for less than $300 if you watch for a sale. The cheapest I've seen them
    in quite a while is $290. But it's like anything else at HF, you're crazy if you pay full price. :)
  16. raYzerman
    raYzerman Member
    Millgrove, ON
    Some DIY ideas.......
    vikingGoalie likes this.
  17. OOTV
    OOTV Insider
    Although I have more than one stand option, the Abba Skylift is the one I use for long term projects. In fact my 5 Gen is currently on it now, as I'm doing some tear down and replacement project at the moment. Otherwise for everyday maintenance, I use the Pitbull stands front and rear.
    Diving Pete likes this.
  18. Diving Pete
    Exactly the same as me - think I use 6 other types of stand & a Abba Superbike stand. The skylift is by far away the most useful kit but would love it motorised or air driven.
  19. mello dude
    Romania
  20. mhzpower
    mhzpower New Member
    Brunei Darussalam
    Vancouver, BC
    I modelled up the Abba lift and had my dad make it.
    My 5th gen is on right now for a head bearing and tire change.
    I like the freedom it gives to work on almost the entire bike at the same time.
    RllwJoe likes this.
