Just a reminder...
Discussion in 'General VFR Discussions' started by paul.miner, Jun 22, 2010.
  1. paul.miner
    paul.miner New Member
    Not even the centerstand will necessarily hold up on hot asphalt:
    The cases protected the fairings pretty well, the only scrape was near the turn signal. My right mirror is broken though, and it tweaked the right handlebar just a little bit. Had to be pushstarted too because the battery didn't want to work after lying on its side (seemed charged up by the time I got home though).
    I even had a metal plate for the kickstand with me, but I thought the centerstand would be fine... lesson learned!
  2. TOE CUTTER
    That sucks, how hot was it and where are you located?
  3. paul.miner
    Wichita, KS. I think it was in the 90s.
