Just got one!!!!!
Discussion in 'Introductions' started by smalls408, Jan 14, 2008.
  1. smalls408
    smalls408 New Member
    Hi my name is Manuel and I just got an 1984 VFR700. How often should I change the oil?
  2. Ravage776
    Ravage776 New Member
    Bienfait, Saskatchewan
    According to my manual Manuel.....it say every 4000 miles. But it could also be at whatever interval you prefer. Take good care of it, and it will last longer.
  3. derstuka
    San Diego, CA
    If it is conventional oil, I would change it every 3,000, or at least once every season. If you run a good synthetic, I would extend it to around 5k or so. It really depends a lot on your riding conditions, and riding style. There are a bazillion different opinions on what type of oil to use and when to change it.
    Oh, and welcome to the forum!
  4. smalls408
    Oil change
    Thanks for the help everyone. I mostly ride on the freeway bought 50 miles each way. I will probably change it every 3,000 and run some good oil in it.
  5. pontiacformula99
    pontiacformula99 New Member
    Smyrna, TN
    I change mine at the start of each season. I do the bike and the lawn mower all in the same day.
  6. JosephC
    JosephC New Member
    Hello There
    I change my oil about every 3000 miles and I use Castrol GTX 5W-30. This is what I have use in all my bikes with no major problems. I did this with my 1985 Goldwing Interstate. The Goldwing has 80,000 miles on it and still runs like the day I picked it up new at the dealers.
  7. smalls408
    Gears
    Some times when I am about to take off the neutral light is off like I am in 1st gear but its like it slips out of 1st into neutral can my tranny or clutch be going bad?
  8. reg71
    Sikeston, MO
    does it actually go back into neutral or just slip instead of pulling?
  9. RVFR
    could be a dirty contact too. Or a tricky switch, On the matter of Oil (ya gota love an oil question)
    Every 2,3 4 sometimes 6K is fine, it's your call. now that said I change mine every 2000, but that is me. and I use Amsoil. with an OEM filter ;)
  10. smalls408
    Gears
    It actually goes back into neutral. Weird thing is that my neutral light doesnt come on and then I have to step down on it really hard unlike the other gears. It only does it some times when I am about to take off.
  11. reg71
    Sikeston, MO
    that sounds like it's not completely getting into gear. mine does that occasionally if I dont shift decisively. I have pretty much decided it's probably me as it only happens every once in a while. I'm not sure that it's the same problem for you, though. Some of the other suggestions sound like a good starting point.
