Just Joined----Clock doubt RC24II (and pic)
Discussion in '1st & 2nd Generation 1983-1989' started by tylerdurden, Nov 9, 2007.
  1. tylerdurden
    tylerdurden New Member
    Hello.
    I´ve just joined this perfect forum for me, as far as i own a VFR 750 89 RC 24II. I´m from Spain, so first of all i´ll ask u to apologize me for my english.
    that is.
    I bought it on second hand market and there are a few things to fix/complete to make it be complete.
    One of them is the clock under the rev. and speed meter. I´ll be very glad if any of u could please upload a picture of that part.
    Thank u and V`ss for everybody
  2. keny
    keny New Member
    Finland
    city of Karjaa, Finland North Europe
    Hi there.
    I´m also from europe, so I know what you mean whit RC24II.
    Moust on this forum seems to be from north america, and they didnt get the real RC24II, just the FII which is basically the regular -87 model in europe.
    The 2 first year of the RC24 (and RC26 700cc version) didnt have the clock you have problem whit. Hope you get all sorted out. Your bike looks mint!
  3. reg71
    Sikeston, MO
    :smile:nice bike. your English will not be a problem here as most Americans still have trouble with learning English.:smile:
  4. tylerdurden
    up.
    Nobody has a pic of that clock?
    I´m quite desperate.
    Is the regular model 87, the RC24 (I)?
    As far as i know, the diferences between RC24 I and RC24II are:
    (translated from a Spanish forum):
    PARTE CICLO
    Estas són las modificaciones más importantes. La horquilla pasa a ser de 41 mm, cambios en el funcionamiento del Pro-Link y en el amortiguador trasero. La rueda pasa a ser de 17 pulgadas (en la primera versión eran de 16 delante y 18 detrás) con neumáticos de mayor huella y llantas de nuevo diseño (derivadas de las de la CBR). Se mantienen invariables las cotas fundamentales de geometría y el chasis. Para optimizar la frenada se adoptaron discos de 296 mm para la rueda delantera, manteniéndose el trasero en 256 mm.
    DINAMIC BEHAVIOUR:
    These are the most important modifications. The front fork is now 41mm sized, changes in the Pro-link function and the rear shock.
    Wheel is now 17 inches (in the first version vas 16 inches in the front wheel, and 18 in the rear one) with wider tyres and new designed wheel rims (similar to CBR). No changes for main geometry and chasis. For optimize the braking, nex 296 mm brake front disk and 256mm for the rear one.
    CARENADO, ESTETICA Y MANDOS
    Cambiaron las dimensiones y ubicación de las salidas de aire caliente para tratar de reducir uno de los mayores defectos de la primera VFR, el excesivo calentamiento de las piernas del piloto. El carenado tiene ahora una forma aerodinámica más acentuada, es mas largo en la quilla y se extiende hasta más atrás y está construido por más piezas para facilitar el mantenimiento.
    Dimensional changes for the bodywork and hot air exits, trying to reduce one of the main fails in the first VFR, Excesive heating in pilot legs. The bodywork aerodinamic shape is now more accentuated, longer in the keel, and divided in more parts to make easy assambling-desassambling operations
    Los intermitentes delanteros están ahora integrados en el carenado mientras que los traseros son más pequeños y están más juntos. Los escapes son más refinados gracias a unos silenciadores revestidos de acero inoxidable, la cúpula es regulable en dos posiciones, las piñas de los mandos eléctricos son mucho más refinadas y la instrumentación, con un aspecto ligeramente distinto, incluye ahora indicador del nivel de combustible y reloj.
    Front turn signals, integrated now in the body, while rears are now smaller and nearer. Exhaust pipe is covered with stainless steel silencers, front dome IS REGULABLE IN TWO POSITIONS, electric controls in handlebar are thiner and more refinated, and clocks are quite diferent, with a fuel level indicator and a clock (THE ONE I WANT A PIC PLEASE!!!!)
    También cambiaron las estriberas del pasajero, ahora en aluminio y mucho más bonitas. En definitiva, un cuidado más maniático aún de los detalles en una moto ya casi perfecta. Aparece por primera vez el color rojo que se convertirá con el tiempo casi en un emblema de la VFR
    Changes in the feet support for rear companion, now in aluminuim and much more beautiful. In conclussion, a more maniatic care for details in a bike almost perfect (the vfr24I). Appears for first time the red color, that with time will be an emblem for the VFR
  5. tylerdurden
    Motor variations, handling, colors, brakes, fuel waist, etc.. in the next chapter after adds.
    V´ss
