K&N power commander??
Discussion in '6th Generation 2002-2013' started by Donnelly317, Mar 8, 2014.
  1. Donnelly317
    Donnelly317 New Member
    I found this forsale. I can not find anything on a K&N power commander. Just a demo jet... it came off a 98 will it work on an 03? I dought it will but I had to ask because some of the dyno jet ones I seen did 98-09..
    Sent from my SCH-I535 using Tapatalk
  2. OOTV
    OOTV Member
    From what heard and have seen posted here I believe, the Power Commander V will work on 5 and 6 Gen so I would imagine this would be interchangeable too. The only issue is whether the K&N software is even available or for that matter will the DynoJet software work if it isn't (This looks like an OEM piece from DynoJet to me), and is that even available either. I work in an industry where equipment is antiquated and replaced all the time, and most of the time product end of life also means support and available parts too.
    Personally, unless you know you can get all the other bits you need for this, I would pass. Something else to consider, is there a Dyno tuner near you who will work with this unit? Sometimes as the old hardware "passes away" so does the knowledge of working with it.
  3. Allyance
    Allyance Member
    Germany
    East Bay, California
    Looks like someone put the decal that came with his air filter on his PC II!
  4. anikmankar
    anikmankar New Member
    India
    India, Mumbai
    Looks earlier PC with k&n sticker
  5. Donnelly317
    You know what under the II it looks like it says dyno jet! Hahaha. So I would say its a dyno jet power commander II so will I be able to put 03 maps on it??
  6. Allyance
    Allyance Member
    Germany
    I have a PC III USB, in checking their web site, I didn't see any support or maps for the II.
    Problem is, how do connect it to your PC, more than likely with an serial cable, which modern computers don't have.
    I would look for a used PC III USB so you can load the correct map with a USB cord.
    Of course you can get a PC IV or PC V.
  7. nih
    nih New Member
    findlay, ohio
  8. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    You need to start a new topic. Entitled "has anyone put a power commander 2 on a sixth gen?"
    Then beg for a map. Pc2's are great. They offer ignition advance.
