Keeping a pannier mounting frame bolt from backing out.
Discussion in 'Mechanics Garage' started by Gnarlymutt, Jul 12, 2016.
  1. Gnarlymutt
    Gnarlymutt New Member
    Kansas City, MO
    Pretty simple post. The mounting bracket for my GIVI Monokey bags mounts to the underside of the passenger foot pegs. I've lost 2 nuts off the right side in the last month while riding.
    What's the best way to keep these from backing off due to vibration? Loctite Blue?
    Mutt
  2. GigemVFR
    GigemVFR New Member
    TEXAS
    Yup, I would say the blue. Red if you want more permanent
  3. jev.
    jev. over there
    Or locknuts
  4. Scubalong
    +++++++++1
    Jev for President :wink:
  5. Dead Eye Dick AKA Carpy
    Dead Eye Dick AKA Carpy New Member
    Chill Out City
    Nyloc nuts, will stay there forever but you can remove them easily if you need to
  6. RobVG
    RobVG Member
    White Rock BC
    Stover nuts are even more secure.
    Never tried to find them in metric though.
  7. jev.
    jev. over there
    What the heck is a stover nut? If you ask me, it sounds made up.
    Sent from my XT1575 using Tapatalk
  8. RobVG
    RobVG Member
    White Rock BC
  9. GigemVFR
    GigemVFR New Member
    TEXAS
    You're trying to keep the nuts from coming loose. Thought you were trying to keep bolt from coming out of mounting bracket (with nut welded to bracket) from the title. Did not read whole post close enough. I would go with nylon insert nut like below as example. I assume these are like the Nyloc mentioned above? +1 for those.
    https://www.fastenal.com/products/f...072 Nuts"|~ ~|categoryl3:"600081 Lock Nuts"|~
  10. jev.
    jev. over there
  11. RobVG
    RobVG Member
    White Rock BC
    In critical applications nylocks should only be used once.
  12. jev.
    jev. over there
    Agreed....
    Although, I reuse them all the time. Cause I'm a rebel and stuff...
  13. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    All good advice except stay a way from lock washers, they can break from vibration. Nylock's or Loctite would be the best choice IMO.
  14. 34468 Randy
    Never knew those nylon inserted nuts were meant to be a one time use only. Learn something every day. If I ever have to use one on a critical application, I will be sure to buy new. Well, I have a whole pile of new ones already. Had am empty tray in my nuts and bolts thingy that needed to be filled so I bought a bunch of those.
  15. 34468 Randy
    You are too hard on yourself. JEV FOR PRESIDENT!
    You should post a picture of Hillary and Donny getting it on as your new avatar.
  16. Gnarlymutt
    Kansas City, MO
    Whoops, yep! Sorry, I totally meant the nut kept backing off. It's an 10mm nut if I'm remembering right, and my local Home Depot didn't have the largest selection of metric options. Think I'll just use the loctite for now. Thanks again!
  17. jev.
    jev. over there
    I have a rep to protect you know.
  18. Allyance
    Allyance Insider
    Germany
    East Bay, California
    Try ACE Hardware, my two local stores have whole isle of all kinds of nuts, bolts and assorted fasteners.
  19. Badbilly
    Both nuts and bolts can be swaged. A centerpunch and a hammer is needed. Not the famous torque hammer. Maybe the guy who invented the nylocks figured that they only work once was trying to boost sales. My coffee cans full of all kinds of stuff proves it. I promise some day to organize it all. Someday..
  20. 34468 Randy
    If you strike out, PM me with what you want and your postal addy. I will send you one. I either have what you want or can get it easily. I think they cost about 10 cents each. My shipping and handling will be alout 25 bucks. Is that OK?...just mess'n. That would go through letter mail for one or two nuts.
