Kickstand tang clearance with Knight Design lowering pegs on 5th Gen?
Discussion in 'General VFR Discussions' started by garcenw, Apr 24, 2019.
  1. garcenw
    garcenw New Member
    I'm contemplating ordering the Knight Design lowering pegs for my 1998 VFR800. For those that have tried the KD lowering pegs on their 1998 - 2001 VFR800, I have a question:
    Is there an issue with kickstand tang clearance when you reach your foot under the shift lever to upshift? I ask, because, visually, it seems like the area of the foot under the arch may hit the tang when you reach under the shift lever. By "tang", I mean the protrusion you use to deploy the side stand.
    Thanks.
    - Walt
  2. garcenw
    garcenw New Member
    I took a pic today to better describe my concern. In the picture below, which is with the stock setup, I took my boot and placed it on the peg with the shift pad of the boot just under the shift lever rubber. There is a slight upward torque on the boot to ensure it is snug against the shift lever. If you zoom in on the scale in the pic, you can see there is approximately 7/8" between the top of the tang and the sole of the boot. Now if you lower the peg 1-3/8" as Knight Design claims and you lower the shift lever a similar amount, it stands to reason that your boot can hit the side stand tang. Now I realize that you may not necessarily lower the shift lever the same amount as the pegs, but tang contact with the boot still seems possible, perhaps likely. What my picture does not capture is what actually happens dynamically, i.e. in actual usage. It is possible one's foot isn't that far inboard when shifting. If contact does occur there are things you can do, such as bend the tang, trim the tang, or add a spacer to the stand's stowed position travel stop, but I'm just wondering what the actual users are experiencing in regards to this.
