Kickstands....eh?
Discussion in '1st & 2nd Generation 1983-1989' started by Krakensnackz, Jul 5, 2012.
  1. Krakensnackz
    Krakensnackz New Member
    Outskirts of Philly, PA
    Ok, so first thing I noticed about my VF500 when I got it up and running, was that shifting was a pain in the ass due to the kickstand being completely in the way of my foot placement when shifting. Here's a pic:
    Ignore the bent linkage, I've straightened it out since. It hasn't changed the position much of the shifter, and to be honest, I haven't really found any adjustments that are comfortable, that get the shifter away from the stand.
    Now, here's a pic from APittslife and his stand:
    Look at how much further back the mounting point is on his. The entire assembly is further back. I took a look to see if mine was adjustable, and nope. Welded to the frame. If any of you guys have a second, do me a favor? Snap a pic and post it here of your kickstand/shifter area. Trying to see what the deal is, here. Did Honda change the mounting point? Mine in an '86. I'm close to grinding the welds and moving it, and welding it back on further back, but I want to see if maybe I'm just missing something else, first.
    Because it's extremely annoying.
  2. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
    It does appear to be a bit messed up. I think you are on the right track and should simply grind of the welds and relocate the encumberance before it causes bigger issues.
    Interesting when you compare the pictures. His frame is different than yours when you look at the web that comes down from the swing arm pivot. Wonder why they changed that?
  3. Riggy
    Riggy New Member
    Vermont & Long Island
    Mine was the same way when i got it. The slot that the kickstand sits in was bent outward allowing the kick stand to settle further out than it should. Just put the centerstand up, remove the kickstand and bend the slot back. Havent had an issue since.
  4. tinkerinWstuff
    amen. :pope2:
    stand is bent over time and from fat chicks sitting on your bike with the stand down. Bend it back with BFH and all is well.
  5. Krakensnackz
    Thanks, boys. Me and the BFH are going to go investigate.
    Fat chicks on this bike? Good god I hope not. At least from now on, not happening.
  6. Krakensnackz
    Also looks like my shifter is bent. Actually, bent initially, then bent back... so it's got a twist as well as a bend in it. Awesome!
    Just curious - are other Honda sportbike shifters interchangeable, say from a CBR?
    There's and availability of CBR parts locally, it'd be easier/quicker (and cheaper) than going through Ebay, I think.
    Thoughts? Anyone try it already?
  7. Krakensnackz
    Looking from above, is the shifter supposed to be straight? Or is there a slight bend to the right (looking down from the front of the bike).
    Mine is definitely disfigured. Considering having one fabricated and tapped for a larger toe piece, as well.
  8. tinkerinWstuff
    yours is the definition of fucked.
    I googled "fucked" and saw a picture of your shifter and the push rod.
  9. Krakensnackz
    hahahaahaaa
    Yeah, took me a bit to realize. New to VFs, and nobody around to compare mine to, didn't see how FUBAR'd it was at first.
  10. Apittslife
    Apittslife New Member
    Clarksville, Indiana
    Look in the Original thread, as I posted a pic of mine from above along with the side view.
    But it may be better if someone with the same year as yours, would be nice enough to post a pic of theirs.
  11. krazyderek
    krazyderek New Member
    Nova Scotia
    My '85 VF500 is also a PIA to shift until i get my foot nestled into just the right spot.
    I think i'd be happy slidding the kick stand back about 2" so that the space between the big rubber end, and the sprint was where my foot would go, but mine is also welded :( Did you end up grinding yours off?
    I had a glimmer of hope when i noticed about a 1" of play in the kickstand, but there's no way to bring it in permanently :(
  12. tinkerinWstuff
    This one applies to you
  13. krazyderek
    Nova Scotia
    i don't know if a simple pounding will do it. The stand is pretty straight, and i'd have to aim pretty good to bend the attachment to the frame to accomplish anything that the spring won't undo.
  14. tinkerinWstuff
    Honda didn't sell them that way. So I'm saying from experience that the stand is bent. You have to pull it off, support the two ends on a 2x4, and wack the fuck out of it with a big ball peen hammer.
  15. tinkerinWstuff
    It's important to have the right tools for the job.
    Just to be clear, I'd recommend the one on the far right
  16. krazyderek
    Nova Scotia
    I think my Dad has an old one, i'll give'r a go this morning. Are we talking 5 or 10 wacks? Or is this going to be a short marathon with the hammer with beverage break in the middle?
    I was also going to try just squeezing it with a bench press, but i don't know if i have one that's big and strong enough.
  17. tinkerinWstuff
    5-10 wack range. Takes a couple to ramp up and figure how much it takes to move it without over doing it. Unless you are a better wacker than I.
    Not to be confused with wanker. I probably have that cornered.
  18. Krakensnackz
    I actually ended up solving my problem with... proper foot positioning. Heh.
    I was originally riding it like I was on the KLR 650, which is a dual sport... upright... feet resting flat on the pegs, heels locked it. Someone told me that on a sportbike, gotta be balls of your feet on the peg, then stab-shift (easiest way to explain it), and return foot to position. Realized that if I did that, there was enough room to pop the shifter with just my toes, without interference from the stand.
    Not sure if it solves your issue, but it did mine. AND made me feel like a n00b-ass dope for a few minutes. haha
  19. tinkerinWstuff
    That's it, Honda sold the 500 with bent kickstands impeding the operator controls as a training device.
    Some folks probably paid extra for that feature.
  20. krazyderek
    Nova Scotia
    Well, i wacked and i wacked, then i wacked some more, but that kick stand was not give'n. So i ended up using the vice to pinch the fork part at the top where the bolt goes through, that brought it in a little bit. Then i sat there for a bit looking at everything, when i realized that if it just swung up a little bit more, it would tuck right in under the peg. So i grinded a slot below the fork so that it would swing up a little bit further and voila!
    IMG_0745.jpg IMG_0747.jpg IMG_0780.jpg IMG_0770.jpg IMG_0772.jpg IMG_0773.jpg
    Ahhhh!!!! The freedom! I was even able to adjust the shifter down on notch. The rubber on the kickstand does contact then shifter when i downshift, but it's working well, and if i wanted to shift a little lower, i could always cut off the rubber and supporting section on the kickstand.
