Kinda embarrassing question
Discussion in 'General VFR Discussions' started by Ryan6864, Oct 5, 2020.
  1. Ryan6864
    Ryan6864 New Member
    Quick background been riding for 25 years or so. Last 10-12 have been dirt/dual sport rode sport bikes before but moved to Texas not a whole lot of good rides here. To get to the point just bought a 2008 VFR800 bike felt off when doing u-turn or figure 8. Almost like bike was fighting me wanting to counter steer. Is that just difference in rake I’m feeling compared to say my KLR650 thats making it feel so akward? Bike has never been down basic mechanical check is good. Have I just been riding dirt/dual sport bikes too long that I forgot how sport bikes feel?
    are you sure tire pressures are correct ? just a few pounds low and you'll be fighting the front to get it to turn.
  3. Diving Pete
    I'd be more tempted to say head bearings.
  4. ridervfr
    tyre pressure, could equal a wheel barrel in the handling category, I have seen it first hand. Not on my own machines of course 佗寂
  5. Ryan6864
    Ryan6864 New Member
    Might have been as simple as tire pressure didn't have a guage just used my hand. Will check pressure when I get home. I'll also check bearings.
    Deal was too good to pass $2500 2008 19,000miles never down, few very small scratches, power commander, delkevic exhaust, ASV levers.
  6. fink
    fink Member
    Check tyre wear. squared off tyre will feel funny. also take your time to get used to bike , yes it will feel totally different to the klr.
    34468 Randy likes this.
  7. squirrelman
    your hand ????? how very scientifik :homer:and very unwise and needlessly risky.
    i never ride an unfamiliar bike without checking tire pressure FIRST ! ALWAYS !
    ceptorman likes this.
  8. Ryan6864
    Ryan6864 New Member
    You tend to get a pretty good feel for pressure after a while. Currently ride africa twin and klr650 always airing tires up and down. Can usually estimate tire pressure within 2-4lbs just by feel.
    It was a quick run through the gears not a lap around willow springs. Was confident tires had 25-30lbs in the front more in the rear.
    Head bearing was bad which caused some weird sensations while turning slow.
  9. Allyance
    Allyance Member
    East Bay, California
    I can attest to the effect of front tire pressure. After mounting 4 or 5 new tires over the years, Cycle Gear never cleaned off the build up of old rubber off my 2014 rim. My front had to inflated just about every time I went out, if I didn’t it handled poorly, difficult to turn. I finally put the bike up on my Abba lift and submerged the rim in water and watched the bubbles coming out between tire and the rim all the way around! I thought I had problems with right angle valves.
  10. highway star
    highway star New Member
    North Mississippi
    Wow, that's unacceptable from Cycle Gear! I just had a new rear tire installed at the local Honda. R&R & balance for $30.00.
    They even use black stick-on weights. Been taking my wheels/tires to them for 9 yrs. with no issue.
  11. 34468 Randy
    I really second this as well. You may have already found a solution to your issue but for others who may have similar issues may stumble upon this thread. In the past, the vast majority of my riding was freeway riding to and from work. The tires in such riding doe really develop a wide and very flat surface area. You really do feel the edge when you decide to go for a spirited ride with the tires like this.
