knock knock, [ whats there ?]
Discussion in '6th Generation 2002-2013' started by saxby, May 5, 2017.
  1. saxby
    saxby New Member
    hi there new to the forum and have a new vfr i got tonight and sadly as the title says its got a problem
    its a 2002 vtec with 71k on the clock it starts and doesn't sound to bad. cold or warm to be honest but when applying the throttle a little a v loud clicking comes in
    when riding if you pull the clutch in and then back out it goes away. but again applying some throttle it comes in
    can make a video if it will help . but its not quiet by any means . a very loud tapping noise
    were is a good place to start ?
    most of the clips i have seen dont seem to be that bad
    apart form changing the oil and filter , i plan to do that next weekend
  2. RllwJoe
    RllwJoe Member
    Welcome from another fairly new member.
    Could the noise be from a worn sprocket and chain set?
    If its sloppy the chain might ride partway up on the teeth instead of down in the groves, and if it has a binding link, it may jump back into place.
    Then, when you pull the clutch, the pressure keeping the chain out of the groves is released and all is quiet until you accelerate again.
  3. saxby
    saxby New Member
    right . have done some homework and found this clip online
    https://www.youtube.com/watch?v=YaYSXz2OV2w
    mine is the same . although a little worse at 15s in that knock you can hear is present and woures me to boot
    im now aware about the cam isues with the vtec engine
    does this sound like a classic case of cam failure ?
    and with out knowing no history on the bike, and having 71k miles on the clock.
    am best replace the guide and chain as well?
    and what are the pros and cons of fitting a manual one, how often do they need to be tightened?
    and from looking at the design of the stock honda one . do they need to be replaced? or can you just re tighten the spring / re set them
    i dont mind spending a few quid to put it right , as long as i can put it right .
  4. Legnd
    Legnd New Member
    Las Vegas
    Hey saxby, welcome from another newer member.
    I think Joe has the right idea for tracking it down but given your new response I'm leaning more towards cam chain tensioner (CCT) noise. The video you posted definitely isn't moving and wouldn't have the chain/rear wheel spinning thus eliminating the chain/sprockets in my mind.
    WARNING LOUD, turn volume down first. Check out this video, does it sound like this? https://www.youtube.com/watch?v=DuBb5K6EZDw
    In the comments the poster even responded saying that it was his CCTs.
    Best of luck!
  5. Diving Pete
    I'd also lean towards CCT's. Cam chain tensioners...
  6. Diving Pete
    Take off the fairing and run the bike. If the noise is more on the right side of the engine it will be CCT's.
  7. saxby
    saxby New Member
    thanks for all the advise . dug out my old camera and did a video
    right . here is my bike running
    [video=youtube_share;lB2ErcksjoA]https://youtu.be/lB2ErcksjoA[/video]
    i have only had time to ride it home the once since buying it but that sound you can hear as the revs drop is what im woured about . over all i had a vfr800 vtec some years age . and sold it to put towards guying a house [ it had v low miles on it ] and it sounded smother them this new bike i have .
    is the knock in the video the cct? it does sound louder on the right side of the bike
    as i said before in my last post , what are my options ?
    am best replace the guide and chain as well? or should they be still good at this millage 71k miles
    https://www.youtube.com/watch?v=XG6c_uhrVOw
  8. Diving Pete
    Lets put it this way.. unless you are unemployed / retired & have time on your hands get the standard honda item.
    They fail at 36,000 ish
    They work perfectly till then.
    Yes a bodge job is to retighten the spring (if you take it apart) - but I would put money you will doing this job again soon !
    For the hassle of doing it the standard honda item is a fit & forget.
    The chain & guide I'm not sure ever wear !!
  9. Diving Pete
    You can get the parts from DSS (David Silver Spares), its unlikely you will need the buckets but you will not know until you get the old ones out.
    Also buy 2 gaskets.
    Another tip I have seen is to drill the tiny hole (in the gasket) out a little more to increase the oil flow - I think its 2mm !
    & don't drop the buckets inside the engine...
  10. saxby
    saxby New Member
    ya thanks for the info . i will get new stock ones then .
    from the look of it the manual after market ones seem a good idea. and althow i wont be doing mega miles i do like the idea of fitting and forgetting about it
    the engine does sound off when cold .. but i was thinking that loud knocking when it revs down was something serous . i hope this cures it .
    will treat it to some new oil and filter as well as i have no idea when it was last done
    and just hope i dont drop the bucket
  11. zombie
    zombie New Member
    Guelph Ontario
    Sounds like the cct's to me as well. Mine made the same noise. Not a really big job to change them but research it first. If you do it the way Honda does in the manual it is a big job. There are easier ways to change them without having to remove so many parts. There are some pretty good posts right here explaining how to do it. You might also want to try changing the oil too. Mine made no noise with fresh oil and only started getting noisy when it was time to change it anyway until they got bad enough that that didn't help.
  12. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    You don't fit manual CCT's and forget about them. You have to readjust them every couple of thousand miles. Like, Pete already said a few times, the standard Honda CCT's are the fit and forget (until around 36k miles when they start making noise again). Just get the standard CCT's, as more than likely, the manual cct's will trash your engine, unless you get the tension just right and reinspect/adjust every few thousand miles. The manual CCT's like to leak oil out of the adjuster too....
  13. saxby
    saxby New Member
    That sounds like good advise . Will order them soon.
    Hopefully it will sound sweet after that .
  14. Hero Danny
    Hero Danny New Member
    New England
    I found this video which may be of use to you.
    [video=youtube;XG6c_uhrVOw]https://www.youtube.com/watch?v=XG6c_uhrVOw[/video]
  15. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    I would love to see a 25k mile review of this CCT reset. My guess is it will only get you a few hundred or maybe even a few thousand extra miles out of the CCT. I would just be worried about the fail nature of the CCT after being rewound once or twice. Will it just be a soft fail like normal, where nothing breaks, but it just gets noisy? Or will it be a hard failure and break some stuff?
    Sent from my Nexus 6 using Tapatalk
  16. Hero Danny
    New England
    I agree... probably better off buying the part. Especially since they can be found for like $75 brand new on ebay.
  17. sunofwolf
    sunofwolf New Member
    I have aaa towing good for four 100 mile tows. Gee I put them together and that's a 400 miles tow. I don't know if you could do that but BB Knows how!:snowman:
