LED brake light bars
Discussion in 'Mechanics Garage' started by duccmann, Jan 20, 2012.
  1. duccmann
    Need help,(no jokes) I saw a thread a few weeks ago about these little LED light bars with 12 bulbs per bar that you can mount on each side of your license frame, so when you brake they pulse three times and then stay on (BRAKE LIGHTS). They look like the ones that are in the grills of the pick ups they use for the fire stations, small but very bright. OK, thanks
  2. 34468 Randy
    Google Whealen, Code four or something like that for Emergency Vehicle Lights. Or drop in to your local fire department and ask them who does their lights. There are all sorts of lights out there that are avalable to you. I have no idea of the cost. I "may" have something to show you in a couple months as the supplier of my department's caution lights also does many local police forces' lights and may put something together for me. I have follwed a bike with what you are speaking of and they are very effective, especially if they are LED lights.
  3. 34468 Randy
    Or how about this system with simple LED lights. This is a module that you can order and hook up. I should have turned ouff the signal light befroe I vidoed this:
  4. rbednar
    rbednar New Member
    Schooley's Mountain, NJ
  5. duccmann
    Thanks rbednar . Thats what I'm looking for. ;)
  6. tinkerinWstuff
    have wanted these myself. Local police bikes have them and it's pretty tough to miss when they start braking.
  7. rbednar
    rbednar New Member
    I was looking at this for my VTX. Where would you mount it on the VFR? Under the taillight?
  8. duccmann
    Hey Tink, do the cop bikes have just one or two mounted-------- $55 each . I would think one would be sufficient
  9. tinkerinWstuff
    they have the whole top and bottom edge of the trunk trimmed in LEDs as I recall
    I'm sure they have some custom installation.
  10. duccmann
    OK, now where do I find a LED replacement bulb for my brake light ? Thanks
  11. stoshmonster
    stoshmonster New Member
    Here are just a coupla places where you can find the 7443 dual circuit Red LED replacement bulbs.
    If you decide that you're going to install LED replacement bulbs in your '02 don't be a cheapskate Duccmann,remember these are your brake and tail light bulbs that you're replacing.
    There's lots of different styles to choose from so get yourself some decent high end LED bulbs that are going to throw out a huge amount of light behind you.
    Super Brite LED's has them. Click me.>>>>>LED Brake Light, Turn Light and Tail Light Bulbs - Super Bright LEDs
    Autolumination has them. Click me.>>>>>Tail Light Brake Light Turn Signal LED Bulbs
  12. leof
    leof New Member
    Seach the items on ebay
  13. DaHose
    DaHose New Member
    Napa, CA.
    I bought my 2K with an LED conversion tail light
    and flasher module installed. It works great. I highly recommend just adding the $20 Oviedo flasher module linked above and then you can use whatever taillight assembly/configuration you wish.
    Jose
  14. Davis5g
    Davis5g New Member
    Pittsburgh, PA
  15. donald branscom
    donald branscom New Member
    Guerneville CA
  16. Matasickle
    Matasickle New Member
    CT
    How much and where.. I doubt this will fit into my "budget" but would like to know just for shits and giggles.
