LED lights on my 07 VFR
Discussion in '6th Generation 2002-2013' started by oh whell, Nov 24, 2009.
  1. oh whell
    oh whell New Member
    North-East Florida
    Title XXIII MOTOR VEHICLES Chapter 316 STATE UNIFORM TRAFFIC CONTROL
    316.2397 Certain lights prohibited; exceptions.
    (1) No person shall drive or move or cause to be moved any vehicle or equipment upon any highway within this state with any lamp or device thereon showing or displaying a red or blue light visible from directly in front thereof except for certain vehicles hereinafter provided.
    316.224 Color of clearance lamps, identification lamps, side marker lamps, backup lamps, reflectors, and deceleration lights.--
    (2) Rear clearance lamps, identification lamps, and those marker lamps and reflectors mounted on the rear or on the sides near the rear of a vehicle shall display or reflect a red color.
    316.225 Mounting of reflectors, clearance lamps and side marker lamps.--
    (1) Reflectors, when required by s. 316.2225, shall be mounted at a height not less than 24 inches and not more than 60 inches above the ground on which the vehicle stands, except that if the highest part of the permanent structure of the vehicle is less than 24 inches, the reflector at such point shall be mounted as high as that part of the permanent structure will permit.
    (2) Clearance lamps shall, so far as is practicable, be mounted on the permanent structure of the vehicle in such a manner as to indicate the extreme height and width of the vehicle. When rear identification lamps are required and are mounted as high as is practicable, rear clearance lamps may be mounted at optional height, and when the mounting of front clearance lamps results in such lamps failing to indicate the extreme width of the trailer, such lamps may be mounted at optional height but must indicate, as nearly as practicable, the extreme width of the trailer. Clearance lamps on truck tractors shall be located so as to indicate the extreme width of the truck tractor cab. Clearance lamps and side marker lamps may be mounted in combination provided illumination is given as required herein with reference to both.
    316.226 Visibility requirements for reflectors, clearance lamps, identification lamps and marker lamps.--
    (3) Side marker lamps shall be capable of being seen and distinguished under normal atmospheric conditions at the times lights are required at all distances between 550 feet from the side of the vehicle on which mounted.
  2. oh whell
    oh whell New Member
    North-East Florida
    If you wanted, mount your strips, print the law and ride?
    But if i dont know what the law really states i might be in trouble getting pulled over and trying to tell them the law?
    Im not a cop and i dont know how this really reads.
    Does anyone else know any more about this?
  3. 02 VFR Rider
    02 VFR Rider New Member
    what do you want to do????
  4. oh whell
    oh whell New Member
    North-East Florida
    i have a Red bike and i wanted to put some red LED's around the frame to where it would glow off of the motor and frame to accent my ride.
  5. Scubalong
    Go for it, I like blue..................
  6. 02 VFR Rider
    you just cant be riding around w/ those on all the time or you will get a ticket
    I have seen alot of folks hide them under the plastic w/o getting any sh*t from the poo poo
    AWP34 likes this.
  7. oh whell
    oh whell New Member
    North-East Florida
    That was my intent under plastic.
  8. 34468 Randy
    Sec. 316.224
    (1). No emergency type lights
    (2). No white light to rear
    Sec. 316.225. When reflectors and lights are required, they must be properly mounted
    Sec. 316.226. Must be proper lights not some goofy think you buy at the 5 and dime.
    I think most jurisdictions would look at those lights as "Unauthorized" and you would stand to get tagged if operating on a road. Each state/province is a little different but basically everyone's equipment laws are almost cookie cutter the same.
  9. Cundalini
    Cundalini New Member
    Sacramento CA
    Mount em and use em while your bike is parked, just not when your rolling ( or you will get a ticket if caught ).
    I had a sick little minitruck and I just used the lights while parked.
    Of course I am paranoid about people f*cking with my sh*t so I only used em when I had view of my truck, because it obviosly attracts attention.
  10. oh whell
    oh whell New Member
    North-East Florida
    I have about a week before my fairings come back from the paint shop. :thumbsup:
    I have a few ideas of where I can place them.:eek:
    Now all i need is to pick the right color.:confused:
    (more over the legal color or good placement):crazy:
  11. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    And they called him "Pimp-a-licious" baby!
    BZ
  12. jasonb92
    jasonb92 New Member
    Bellefontaine, OH
    I am a law enforcement officer in Ohio, the big reason for no red and blues facing forward is because they are reserved for law enforcement. The law is to keep people from displaying red and blue and causing people in front of them to think it is the police. As long as you keep it under the fairings and it is not flashing you should be okay. But different jurisdictions have different ordinances. The state has it's revised codes and each individual city can have more strict codes. Check with your local law enforcement agency to see what laws may be on the books in your location not just Florida as a whole.
