Left rear turn signal lens assembly for '94 VFR??
Discussion in '3rd & 4th Generation 1990-1997' started by bloominguez, Apr 20, 2021.
  1. bloominguez
    bloominguez New Member
    Repairing some broken plastic, thought I had all the parts I needed .... but I was wrong.
    Anybody have a left rear turn signal lens assembly for a '94 VFR?
    Part number: 33656-MZ7-671
    Not available online anymore, hoping someone has one I can buy, otherwise I'll have to jury rig something.
    Not much easier to find, but you can run the 1990 - 93 red lenses as turn signals until you find the amber one.
  3. bloominguez
    Agree, and I have a line on that solution via another channel.
  4. Bud12oz
    Bud12oz New Member
    Try to google "Boonstra" motorcycle parts. They are in England I think? They have remans of the 4th gen amber turn signals. $36. But shipping will be $20.
  5. klotzfreak
    klotzfreak New Member
    Litchfield, Minnesota
    A8F9A2A3-BC15-43E6-B078-7F251486D6D7.jpeg I have a rear but am not sure if it’s a left or right.
  6. bloominguez
    I'm going to guess that's a "right" because the flat part that "wraps around" is on the bottom.
    Thanks, but I did finally find what I was looking for. I found some *red* bulbs from someone in Canada who had swapped out his red for amber back in the day, to do the turn signal conversion on a '90-'93 VFR. So my turn signal bulbs are red now, oh well.
  7. VFR750F3
    VFR750F3 New Member
    Stamford CT & Weeki Wachee FL
    That's excellent news!! I don't need any now, but if they'd had them a few years ago, I'd have bought. Hopefully I won't ever need any, but if I do...
  10. VFR750F3
    VFR750F3 New Member
    I bought one of the Boonstra reproductions recently, rather than try to polish one of my originals. I found a new genuine Honda light for the other side.
    It's an OK product if you really need one, but the hole for the light socket is poorly shaped and the socket isn't tightly held. The lens corner at the top by the taillight isn't quite right, so there's a small gap. The bulb/reflector housing is black instead of the original orange, so I think the lens, when not lit, looks slightly darker. The screw hole in the mounting tab is located about 1/4" off, actually I think the tab is off, so you have to drill a new hole close to the edge of the tab and wedge the speednut into place.
    3/10. For emergency use only.
    FWIW
  11. vmotorman
    vmotorman New Member
    Olathe, KS
    Check with jethro! He’s parting out a crashed one in the Classified’s.
