Left switch gear replacement 1989 fk
Discussion in '1st & 2nd Generation 1983-1989' started by Thumbs, Sep 16, 2023.
  1. Thumbs
    Thumbs Member
    Bath(ish)
    The indicator section of the switch has collapsed due to rust and is shorting the headlights switch
    Is this unique to the 89 or will other years fit?
    No problem if it needs re wiring
    90-97 VFR and 91 - 98 CBR600 I've sourced have been nearly plug and play, if not actually p n p. Re pinning to match colors is the extent of modifications I've found here in the U.S.
    Thumbs likes this.
