Lights going bright when leaving throttle
Discussion in '5th Generation 1998-2001' started by Stephenh198, Oct 6, 2014.
  1. Stephenh198
    Stephenh198 New Member
    Hello. My 1998 Vfr is doing something funny. While I'm accelerating my lights are normal, but as soon as I leave the throttle the headlights and dashboard lights go brighter. Is this normal?
  2. Allyance
    Allyance Member
    Germany
    East Bay, California
    No, not normal. For some reason the regulator section of you R/R is not doing it's job, output voltage should remain fairly constant. Check all connectors for corrosion, clean and burnish contacts if they look powdery. Take some voltage readings at various RPMs.
  3. NormK
    NormK New Member
    Sounds like it is heading for a meltdown, check the connectors on the rec/reg for any signs of burning,melting
  4. mello dude
    Romania
  5. Stephenh198
    Thanx for the help guys. I will take a look at it as soon as I can get some time.
  6. Quattro73
    Quattro73 New Member
    Norway
    Norway
    It's normal that the voltage rises slightly around idle speed, 0.2 - 0.3V. Did so on mine 5.th gen with old r/r, also does so with new r/r ;)
  7. Stephenh198
    So. I finally checked my charging system. Tested while bike was cold and again after a good long drive. At idle I'm charging at 13V and at 4000+ rpms 13.9v-14v, so the r/r is clearly not the problem. Had my battery load tested, and tested bad. Replaced the battery and its now 100%
  8. NormK
    NormK New Member
    Makes no sense that shutting the throttle makes the lights go brighter, unless it is the fact the ignition starts to draw less as the revs drop but for the battery to be that low I would have thought you would have had starting problems, but anyway glad it is sorted
