Lil bit o' leakage
Discussion in 'Mechanics Garage' started by tmyoungjr, Sep 21, 2010.
  1. tmyoungjr
    tmyoungjr New Member
    Rochester, New York, United States
    Lil bit o' leakage [Resolved - I hope!]
    I've had the bike for a month now. Ridden it pretty much to / from work as I am able to (not a ton of time recently for fun riding though). No issues at all.
    The other morning its about 45 degrees out. Ride into work around 5am. Come out in the afternoon (65ish) and notice some minor leakage on the ground. It's clearly coolant, but again not a ton. Just some splatter on and around the side stand and the hoses on that side of the bike. Get home, not noticing anything really new, clean off whats there and let the bike sit. No new leaking. Inside of the fairing is clean (ie its not collecting a slow leak keeping it from hitting the ground or anything). Im unable to ride for the next bunch of days. The bike is garage kept and the floor is dry / clean with nothing on it from the bike.
    Last night I pull the left side fairing off, coolant level is just around the low mark. Add enough to get it halfway between low / high. Inspect all visible hoses / connections. Nothing has fluid on or around them, nothing right at the connections showing seepage either. Button it back up.
    Rode in this AM - again between 45-50 out. And again there's fluid down near the kickstand, also on the inside of the left fairing - only on the bottom corner, basically underneath the plastic coolant tank.
    I'm looking for thoughts / ideas. I suspect that I'll wipe everything down before the ride home this afternoon (supposed to be 80ish) and i'll have no leakage / spatter when I get home.
  2. tinkerinWstuff
    likely lower radiator hose just needs a little tightening on the clamps. If it was leaking anywhere up top, you'd smell it and the coolant would evaporate (on slow leaks) before ever making it to the ground (hot motor).
  3. derstuka
    San Diego, CA
    How has your coolant temp been lately? Just wondering if it was overheating and overflowing. As Tink suggested, check all of your radiator hose clamps, and also inspect the hoses as well. It is also possible (but probably unlikely) to have a small cut or pinhole leak on one of your hoses. There are many other possibilities, however, best to start with the easy/obvious and go from there. You may want to let it run for awhile with the side panel off, even take it for a short ride down the street to warm it up if need be, then inspect holes/clamps for leaks..heck even check the drainplug area. Once you get the leak figured out, (if it has been awhile) a coolant flush/change would not be a bad idea....with MC engine safe coolant of course.
  4. tmyoungjr
    my intent is to pull both side panels (even though right side is clean). perhaps even to / from work.
    unfortunately with the panels on visibility is nil. Once it's nice cold out again, i'll give it a go and see what i see!
  5. tinkerinWstuff
    on my old 1st gen, there was a coolant tube on each head that is sealed with an o-ring. In the cold weather, the o-ring would shrink and the the tube would leak slightly until it warmed up. No such tube on my 3rd gen and have no idea on the 5th. But the other thing is, when the tube would leak, it would collect on the motor and once the motor heated up, you'd smell coolant.
    My 3rd gen just developed a coolant smell this weekend. No puddling on the ground and I'm guessing it's related to the T-stat housing or connecting hoses to same.
  6. squirrelman
    If dripping is coming from the small hole on the underside of the water pump, there's a bearing and seal going bad in there.
    As mentioned above, radiator hoses tend to squish down over time and could stand a periodic re-tightening of the clamps.
  7. dko15
    dko15 New Member
    Northern California
    Squish down over time?
    Carefull what you read or KNOW, get a real or professional opinion
    Not for nuthin, but a hose usually gets weaker over time and expands more with pressure and heat, if hose clamps were properly fitted when installed, you would not ever have to worry about the clamp being tight.
    Coolant change lately? (air bleed incorrect?)
    T-stat stuck? ( too much heat and pressure causing the radiator cap to let off more coolant than usual and blow over the overflow tank)
    Filler up often til you get her fixed
  8. tinkerinWstuff
    Hey - my opinion is "real" and it's worth what you pay for it on an internet forum rather than going to your local mechanic.
    I also know history on this bike from the previous owner and happen to know the guy just fought with a T-stat change while stroking his chicken. The odds of the job having been done properly are slim.
    :funky:
  9. tmyoungjr
    bahahah - that is an awesome image!
    like I said once I can pull the lower fairing off both sides and then get it out when its cold again (which should be soon the way our weather is going), i'll give it all a good look. I'm also certain i'll have nothing this evening on the way home with regards to leaking / dripping / etc.
  10. tmyoungjr
    ride home last night, about 78 degrees out. inside lower fairing dry as can be. no noticeable coolant anywhere (or any fluid for that matter). unfortunately no time to pull the fairings and the bike is in the garage out of the rain today.
  11. 02 VFR Rider
    02 VFR Rider New Member
    ha hahahahahahahahahaha --- nice tink.
    stop putting fluid in the over flo, it will find its own level, it never seems to be the mark on it.
    send it back to Elwray for warrenty repair, ha hahaha
    no really sounds like the cold weather mine does the same thing the first few cold days and then goes away.
  12. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    Hmmm, Tink is in CO. Elwray is in Jersey. I'm gonna hate myself for asking this, but WHY do you have a picture with him and a chicken?
    Anyway tmy, I had the same issue on my 5th gen. Random intervals of a few drops of coolant, and always when it was cooler outside. Tightened up all the fittings and seems to have taken care of it.
  13. tmyoungjr
    I found that to be the case on my shadow and was instantly what I thought of here. But I'm not making any assumptions until I can see whats happening. Wish there was more time in the day!
  14. tmyoungjr
    Too damn busy :( Had it out friday for about 1/2 hour - long enough to pick the 8yr old up from his bus stop. Was about 90 out. While waiting for him to arrive, figured i'd look around best I could with the fairings still on. Noticed coolant on the inside of both lower fairings (instead of just the left side). Coolant level still plenty sufficient (so im not leaking TONS). Temperature gets up to about 220ish and hangs out there.
    We had an offer accepted on a house we wish to buy. Now we're working overtime to try to get our current house sold. I'll probably be lucky to have time to just pull the fairings anytime soon.
  15. tmyoungjr
    Since I still haven't had time to even look at this, it was suggested that I just continue to bash elwray. So I will. Whats with the chicken? I mean it'd explain many things i've found with the bike, but still!
  16. tinkerinWstuff
    I understand he used to park the bike in the chicken coup. Since his pride and joy was the VTX and didn't much care for the VFR, the rooster would perch on the bike and watch over his hens. That smell you have is actually bird poop.
  17. tmyoungjr
    OHHHHH that makes so much more sense
  18. tinkerinWstuff
  19. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    Why do cars with two doors called coupes? If they only have one door it would be called a CHICKEN coop.
    When my hoses leak the same in cold weather, I just tighten the clamps and all is well.
  20. 02 VFR Rider
    Tink how did you get the pictures???
