lookin for torque specs
Discussion in 'Mechanics Garage' started by mofoco, Jun 13, 2008.
  1. mofoco
    mofoco New Member
    Vancouver Island, B.C. Canada
    anybody know the torque specs i need to replace clutch in 97 vfr750f engine cover and clutch bolts ....also need the fram oil filter part #
  2. Rev
    Rev New Member
    Olympia,WA
    Fram PH7317
    let me check my manual for the torque specs
  3. mofoco
    mofoco New Member
    Hey thnx um will the ph 6017a work thats the number i managed to find online and i also need the oil capacity i got four bottles of amsoil synthetic.
  4. mello dude
    Romania
    Clutch cover bolts are listed at 9 ft-lbs
    There is a oil filter equivalent chart out there to look up stuff like that. I dont think Fram was a recomended brand. Bosch, Purolator and Mobil one were tops.
    MD
  5. NorcalBoy
    Amsoil also sells oil filters, I just buy the filters when I order the oil from Amsoil..........
  6. mofoco
    mofoco New Member
    Thanks guys! I didn't realize that amsoil had filters, trouble is up here in Canada most of the good stuff has to be bought retail otherwise i have to order from the states and wait, only went with Fram due to availability, and price guess i relay shouldn't cheap out there though. K&n can be had fairly easily as well as genuine Honda maybe ill just get a Honda although that would mean not completing the work until tomorrow.
  7. mofoco
    mofoco New Member
    so anybody know about the clutch basket bolts
  8. DANIMAL
    DANIMAL New Member
    Metairie, LA USA
    clutch center nut (big one in the middle) g thru p models 65 ft-lbs
    r model and onward 80 ft-lbs
    97 fvr750 is a V model So 80 ft-lbs
    the five bolts that hold the plates and springs in
    manual says to tighten them evenly in a criss cross pattern
    until they are securely tightened
    no torque specified. these bolts will bottom out they set tension on clutch plates via springs
  9. mofoco
    mofoco New Member
    Thank u very much, you rock Dude!
