Loose rear sprocket bolts
Discussion in '5th Generation 1998-2001' started by Andrew_rc46, Oct 24, 2013.
  1. Andrew_rc46
    Andrew_rc46 New Member
    North yorkshire
    Omg is all i can say about the bloody rear sprocket bolts coming loose, i stripped it all down for a clean and noticed a loose bolt! so i took it off,loctite added and low and behold after a blast out with friends and every single one was loose, after closer inspection, the thread was f****ed, an ebay purchase later (bike breaking) and second hand ones arrived, so off i went again loctite,tighten and ride..........WTF now these ones are just as before.......i'm lost as to why this would be.:grief:
  2. 34468 Randy
    Did you torque them down to the right torque? Sounds like that is what is happening. Maybe you need new bolts. You should be able to get those at any hardware store.
  3. derstuka
    San Diego, CA
    Sounds like the bolts could be "over torqued" over time causing them to stretch (changing thread pitch). This in turn can sometimes allow an nut/bolt to back out (loosen). That or they just have so much thread lost that they are hosed. :pisser:
  4. ricky
    ricky New Member
    Modesto, CA
    A theory:
    Sprockets and hub can "settle" in. After installing a new sprocket re-torque them after you have some miles on it and check occasionally. If they keep loosening after re-torque then there is problem.
  5. OOTV
    OOTV Member
  6. tinkerinWstuff
    Torque hammers
  7. Scubalong
    Have you try Teflon locking nuts?
  8. Andrew_rc46
    North yorkshire
    i was hoping to find some bolts with holes in, my old 5pw r1 had them on the calipers, that way i could lock wire and loctite them on.
    i think what that you meant are nylock nut! this is a good option and one that i will try, as well as all of the abov.
    cheers guys :wink:
