Loss of power
Discussion in 'Mechanics Garage' started by mikeplayer, May 25, 2021.
  1. mikeplayer
    mikeplayer New Member
    Ottawa Ontario
    • [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    • Hey gang. I have a 2002 vfr800 interceptor with 55000kms on it, two brothers exhaust, power comander and k&n filter. Riding today at highway speed, suddenly lost power. Had to trailer home. The bike will start and runish with significant throttle but is clearly unhappy and won't stay running. It sounds like it may be running on 1 or 2 cylinders. The valves have not been adjusted. Any ideas on the best place to start? Given the sudden and extreme loss of operability, I'm thinking cam chain. I've already disconnected the power commander to no effect to eliminate that possibility. Was thinking plugs as a simple fix but it seems unlikely to be that sudden and drastic. Had no fault indication on the dashboard.
    I'd personally start with checking for spark. Also due to the number of times I've read about it, the early VTEC VFRs seem to be very susceptible to corrosion in some of the connectors. Disconnect, clean, inspect the major players to start with.
    I'm sure a few more peeps will be along. I've worked on one once tracking down a no-start situation. Stupid Fucking Spaceship. That problem is not yours, turned out to be a wrong ignition switch installed by PO after being stolen.
  3. Simon Edwards
    Simon Edwards New Member
    Berkshire
    I'm more of a carb' guy, and there are plenty of others on the forums with far more experience of these, but I'll make a few suggestions if I may?
    Given the sudden loss at speed it appeaers as though something let go under stress.
    If this was a car I'd be looking straight at the MAF sensor(s) for this symptom. Preferably by reading the fault codes from the ECU to confirm it. But on the VFR the MAF appears to be driven by a complex collection of pipes instead of the direct air filter to throttle-body flow you'd find driving it in a car installation. Like I said I'm not used to the VFR setup, but there are a lot more hoses and joints that could throw the sensor out on a VFR.
    As far as I can tell the MAF is F-21 (P/N 37830MCF003) here https://www.cmsnl.com/honda-vfr800-2002-2-england_model5703/partslist/E__1701.html#.YKz7yqHTUUQ
    Which is also item 14 here: https://www.cmsnl.com/honda-vfr800-2002-2-england_model5703/partslist/F__2100.html#.YK1nLqHTUUQ
    I guess that if any one of those hoses were split, or a joint were leaking it'd show up like your symptoms. Or of course the MAF itself or its wiring could have failed.
    If I were betting, I'd be looking very carefully at those 19 year-old hoses and their unions for any hardened rubber and leaks. A smoke tester inserted into the hose where it joins the MAF would show you this without needing to strip the bike down to take a look at each one.
    After that, assuming I am wrong, I'd go with a back to basics check:
    Is it getting enough fuel? So...
    Check for a blocked or otherwise collapsed fuel filter?
    Fuel pump failure. Note: Although rare. just because its buzzing and sounds like its running doesn't mean it is capable of supplying at full capacity.
    Blocked injectors or feeds. Leaky feeds.
    Is it getting the right amount of fuel?
    Failed fuel pressure regulator
    Failure in any of the vacuum hoses that control that regulator.
    Failed ECU causing injector chaos.
    Is it getting enough Air?
    Air filter collapse or blockage?
    Can it ignite the mixture?
    Its unlikely, but I suppose it could have lost one or two coils, or the timing generator could have failed, so check for sparks at all plugs.
    After that I'm out of ideas.
  4. Diving Pete
    Check the earths on the left front mount. If only on 2 it could be that.
    Whats your voltage on the battery & output from stator..
  5. Diving Pete
    A coil pack failing will cause this.
    This will not matter - lol
    Earths
    Nope
    good idea, just unlikely
    Nope not plugs.
  6. Alan1234
    Alan1234 New Member
    Does it run ok when the bike has cooled down? I had almost the exact issue on my 85 VF 500. Once it cooled down it ran great until it warmed up again. Turned out that the screws holding one of the coils to its bracket had come out so the coil was just dangling almost on top of the hot valve cover. I guess the ground on the coil is heat ground and not a regular electrical ground. For me the coil was working properly but was just overheating
